Honestly, I'm dumbfounded that anyone can question the difficulty of making repeatable valid low frequency measurements in small spaces.
Among professional practicians of audio measurement, the low frequency difficulty is as well known and well accepted, as is the fundamental measurement dilemma posed by the time/frequency tradeoff.
It's all about what are we actually measuring imho....direct, reflected, which reflected?
The reasonably hard evidence needed (imso) .....is the other way around......... we need reasonably hard evidence that such measurements
can be made.
Yes sir! All valid techniques should give the same answer.
Both of the techniques, wavelet like I showed, and REW like you showed, give the same result. Both show that 2.03ms is not a perfect substitute for the low-pass filter I inserted into the low-pass channel.
As we know, constant time, and frequency dependent phase, aren't really substitutes for each other.
(tell that to the general passive xover crowd (not meaning you
) Lol
Of course, the more correct process with the wavelet example I showed would have been to negate the all-pass I inserted to get symmetry in the wavelet peaks around the central peak...like would be done in a real world example. Then the minor magnitude dip at 300Hz would disappear.
I haven't used the wavelet method for alignment in several years, because like
@boxerfan88 and others found, results away from nearfield get quickly hard to read.
I have used the wavelet method to explore envelope warping thru xover. And also to explore the outputs of porst and the driver on vented subs (with a mic on each)...really interesting there.
Bottom line imo, use whatever measurement tools we are most comfortable with, that fit the measurement task at hand. For me, it's a combination of Crosslite+, Smaart, REW, & occasionally ARTA, in that order.
Crosslite+ has a nifty post capture tool called Single Wavelet, that is akin to Filtered IR in REW, and wavelets in general albeit with finer resolution. When used with frequency dependent windowing, I has given the most repeatability in reflected environments I 've found. That said, FDW with REW really helps too.
