The question is if you want to "time align" the drivers, then "where those drivers are acoustically located" is a pertinent question. The time alignment concept make sense only if you can approximate the driver (e.g. the woofer) as a point. And the answer to the question of where that point is is not obvious. It is almost certainly frequency dependent, and we may not even know how to define it.That is quite interesting! Never seen that before. But this is not quite what we're after, is it? This mostly shows the point in space at which the waves appear to originate. This is, however, as far as I can understand, separate from the timing aspect of it.
