Bullwinkle J Moose
- Joined
- Mar 31, 2021
- Messages
- 217
- Likes
- 90
Seems like quite a few of you own the Sundara
Have any of you tried custom tuning them?
I immediately noticed how different (Bad) they sound when you cup your hands entirely over the entire outer grill
The sound also changes as you slowly increase the distance of your hands from the grill
The timbre changes and I find it quite pleasing when the hands are angled back about 45 degrees and cover less than half of the Sundara's grill
Cover the bottom and back of the grill with your hands @ 45 degrees angle
The amount of covering and the distance from the grill change the sound considerably
I find the the change to be a considerable improvement when the correct covering is made, and a considerable detriment when the wrong covering is made
Covering the grill in front of the ear sounds wrong
Covering the top of the grill sounds wrong
Covering more than half of the grill sounds wrong
But when you find the right angle / position / amount of covering and distance from the grill, I find that the Sundara can be improved considerably
Now I just need to find the right material and mounting method
Have any of you tried any worthwhile tweaks
I have the round earcup version
