peniku8
- Joined
- Dec 9, 2020
- Messages
- 474
- Likes
- 1,089
Here are a few measurements of the Tight AV Dante to XLR dongle done via DVS.
Due to DVS not being recognized by FlexASIO, the measurements are a little different than the ones I usually provide.
I had two instances of REW running: One with the Cosmos ADC and one on DVS. Cosmos was running 384KHz while the Dante network was set to 96KHz.
The device was powered by a TP-Link PoE Switch that was connected to my PC's 2nd Ethernet port (and nothing else).
Frequency response (via white noise, hence the slight wonkiness):
Nicely flat well into the low infrasonics. Good start!
THD+N@0dBFS: -90,1dB
Same measurement at 50Hz since I couldn't sweep FR vs THD:
Dynamic Range: 108,8dB
I'm especially happy about the lack of mains hum. The noise spectrum is just fairly even noise, which is quite inoffensive psychoacoustically.
And well, that already wraps up my measurements for the Tight AV Dante DAC.
I'll be using this to integrate analog amplifiers into a Dante-networked live sound rig.
Cheers!
Cheers!
