Tidal vs Qobuz experience
Beershaun
MQA is delivered in a FLAC container. There is no such thing as an MQA container.
You are right my mistake. MQA is a codec transmitted in a FLAC container. Which means you must have a local decoder/renderer to decode it that understands MQA Like the Tidal app or Roon app. If you don't then a non-MQA FLAC file must be sent by the server. https://en.wikipedia.org/wiki/Master_Quality_Authenticated
[QUOTE="Regarding Warner, one week ago I could happily download a lossless FLAC album of my choosing on Tidal - now I can’t. I am not sure why I am the one that needs to explain this change. Why is Warner no longer allowing me to do this?[/QUOTE]
This is what I am trying to understand. I don't yet follow how you've been harmed and am seeking to clarify. In what app are you referring to that you can no longer download a FLAC file? What file can you no longer download? I can still download any Tidal file locally in my Tidal Android app. Including the Aretha Franklin album you mentioned. I can't download any of them outside this app or on my Mac Tidal app and never could. So I am trying to better understand what has changed for you. If I stop paying for Master level Tidal I will stop getting MQA files and will get whatever tier I pay for. Whether it's lossy MP3 or lossless FLAC.
samsa
Again, no.
Whatever the container format, MQA is just ordinary 24/48 PCM, with the lowest 8 bits of each 24bit sample "repurposed". When played on a non-MQA-aware DAC, those 8 bits are just interpreted as low-level noise. Effectively, you're getting 16/48 PCM, but without (AFAICT) the noise-shaping dither that would normally be applied.
KeenObserver
Again, no.
And the 16/44.1 MQA. What do you get there?
samsa
MQA CD's ? Horrible!
There, the 3 least-significant bits are repurposed. So you're effectively getting 13/44.1 PCM.
With 16 bits and noise-shaping dither, you can, arguably, push the noise below the threshold of audibility. Not so for 13 bits. And it's not like you're getting to pack a whole lot of useful information in the 3 bits/sample that you've sacrificed.
Hopefully, the MQA CD will suffer a quick and well-deserved death.
abdo123
Brussels, Belgium
i have never heard of MQA CDs so it looks like it’s already dead.
Seriously what were they thinking lol.
Interesting! Did you read the Forbes article?
Which article are you referring to?
KeenObserver
What are these 16/44.1 streams that Forbes is reporting that Warner is supplying to Tidal?
dmac6419
USofA
You have horrible vinyl,tape ,Cd's and digital download that are down-sampled,up sampled you name it.
samsa
Could be a mistake. Or these could be the PCM streams (packaged in a FLAC container) that would normally be intended for an MQA CD.
Edit: Definitely not a mistake. Here's a post from a Roon user showing a 16/44.1 MQA stream. So Tidal really is foisting off that 13-bit crap on their subscribers.
If only. Mostly a plague on the Japanese market, so far.
abdo123
Brussels, Belgium
I don’t understand what’s ‘DRM’ about MQA btw. You seem very informed on the topic so i wanted to ask you.
So at worst case scenario you’re getting 16 bit 44.1 or 48 Khz which is CD quality. Without needing any special hardware or internet connection.
The best analogue electronics, including the analogue stage of the DAC is at around 20-bit, so that is 1/6 of the 24-bit bandwidth unnecessary right there, and most power amp probably at best are 90dB, so even 16-bit is more than needed there.
Why are people so against MQA? It shouldn’t take away from a CD experience anyway. Only add to it if you have the hardware for it.
abdo123
Brussels, Belgium
Okay i just looked that album up, there are two MQA versions.
one that is 16 bit and another that is 24 bit. They sound ALOT different.
400kbps yeah go fuck yourself lmao. might as well listen to Spotify at that point.
KeenObserver
I believe what has been said is that unprocessed 24/44.1 MQA comes out 16 bit. 16/44.1 unprocessed MQA comes out 13 bit.
Beershaun
You are reading it wrong. That is the instantaneous bit rate of the streaming connection at that point in time. Just like any streaming protocol the rate at any given time varies when the file is actually being streamed to the renderer. Your two pictures tell exactly that story. At one moment it's streaming at a connection speed of 1106kbps and the next 410kbps. It has nothing to do with the bit rate or sample rate of the file when the DAC converts it to analog.
Taddpole
No you've read it wrong, they say they cued up two different files. One 24bit and one 16 bit as shown in pics.
It may be that those are the streaming speeds of a moment but that's linked to them being different files.
Beershaun
You are right. Thanks for correcting me. They are two different files. I just didn't want the poster thinking incorrectly that the streaming speed was the file bitrate and thinking they were getting less then they were supposed to get.
