Tidal vs. Deezer vs. Qobuz vs. Spotify vs. Apple Music
adlervft
Luxembourg
That's easy to spot with DeltaWave.
@pkane, could you please help out a bit here? I'm 110% positive that the track from Tidal is identical with the one published on Deezer, just the compression streaming algorithms are different. By looking at the above pics, can you please say some more about these files? Let me know if you need the FLACs, please.
Thank you!
If you have the two FLAC files it's easy, invert the polarity of one and combine with the other one, the result should be silence.
pkane
North-East
Thank you!
If you can upload the FLAC files, I can see more of the details. As is, it looks like there's primarily a difference in the filtering above 17kHz.
Reactions: trl
trl
trl
King of Mods
Iasi, RO
How was the stream captured? Was any of the apps operating in exclusive mode?
Tried with both, dedicate apps and Chrome browser (built-in apps) and found no differences. The recording was done via AudFree Audio via WASAPI Exclusive mode and Non-exclusive (I haven't found any diff.).
Basically, I find that TIDAL is somehow better than DEEZER when using similar bitrate, although I do not understand why they mixed Standard with High Quality, because it's misleading. Too bad TIDAL has no Lyrics and no multi-language support, quite not a good way to address a service globally.
trl
trl
King of Mods
Iasi, RO
There's no way the two recorded files to be bit-by-bit identical, due to different streaming codecs these services are providing, but I'm sure the original tracks from both providers are the same.
trl
trl
King of Mods
Iasi, RO
Thank you!
  • DEEZER_HiFi-Camarero.zip
  • TIDAL_HiFi-Camarero.zip
maverickronin
Midwest, USA
Aren't they supposed to be using lossless codecs at those qualities?
Fluffy
Better in what sense? And how can you definitely know what bitrate you are getting?
As I see it, the difference is due to different filters used. More energy in 18khz+ isn't necessarily "better", it could actually be a deviation from the original recording. I think the best way to know which one is more accurate to the recording is to rip the track of a CD and compare it to what you get in each service (if we assume the CD is the best reference).
Though personally I don't think whatever happens above 18khz matters too much.
trl
trl
King of Mods
Iasi, RO
Well, I'm sure their intentions are good, but they can't deliver bit-perfect lossless via streaming, but I'm sure an A/B test won't tell a difference.
trl
trl
King of Mods
Iasi, RO
The bitrate is what service providers tell, or other website reviewers are telling, but in the end I get FLAC file having almost identical sizes when choosing let's say 320Kbs bitrate on both Deezer and Tidal.
I know what you mean about the energy above 18KHz, but I trust more an audio service that provides as-close-to-lossless-as-possible audio quality, that means no roll-off at all up to 20KHz.
Like I said in my previous posts, I don't think in an A/B test between Hi-Fi and 320Kbs anyone will actually feel a difference, but that's debatable. After all, it's good that the final customer can choose it's own audio quality/price ratio.
trl
trl
King of Mods
Iasi, RO
Could you please elaborate why they can't deliver bit-perfect lossless via streaming?
Their streaming codecs are not perfect, like the Bluetooth codecs that can't deliver a true bit-by-bit audio file to the other endpoint, although this shouldn't stop us to use these streaming options, because we're definitely not feel the differences.
might worth watching.
adlervft
Luxembourg
I'm talking about Tidal HIFI, it should be lossless, streaming FLAC files without any compression.
Fluffy
If this roll off is due to a slow over sampling filter, it has nothing to do with it being lossless. You can have bit perfect playback of a lossless track and apply any filter you like, and it will affect the final frequency response.
You need to separate encoder with container. They can have whatever container and lossless compression algorithm they want, but the end result after decompression is a lossless file. The only limit is bandwidth, and in a desktop setting this is negligible. If you transfer a zipped wav file across the internet, it will not lose any data. Bits are bits.
pkane
North-East
There's very little difference between the files. Adjusting for the differences in the filter cutoff, the difference is about -87dB RMS. Most of the differences are in the least significant two bits of the 16 bit samples (otherwise, the files would be a bit-perfect match). Here's the difference spectrum:
Timing of samples is a perfect match (almost 97dB correlated null debth), so this indicates the the source files were the same, no phase or jitter differences.
Here's the difference file, so you can hear what's different between these two. The gain was adjusted by +50dB:
https://www.dropbox.com/s/z30j1nvnia6t57y/difference.wav?dl=0
Regards,
-Paul
trl
trl
King of Mods
Iasi, RO
Thank you so much Paul! It's clear now that the two providers are using the same master track in their database.
trl
trl
King of Mods
Iasi, RO
pkane
North-East
Looks more like compression artefacts to me. However, given it's 50dB amplification, the differences are indeed tiny and, most likely, hard to spot by ear.
Very similar compression on both tracks, but yes, slight differences are visible (zoomed in):
Zoomed out:
Reactions: trl
Soniclife
Tidal hifi without watermarking matches CD, I've got very deep nulls that way, this should not be surprising. Quite a lot of tracks are watermarked, a much bigger difference than between lossy encoders.
trl
trl
King of Mods
Iasi, RO
QOBUZ vs. TIDAL vs. DEEZER (posted on the first page as well now)
QOBUZ 24bit/48KHz vs. TIDAL Master - almost identical frequency response
QOBUZ 24bit/48KHz vs. TIDAL Master - almost identical files across audio spectrum
QOBUZ 24bit/48KHz vs. TIDAL Master - most of the delta spectrogram is near 0dB
QOBUZ 320Kbs vs. TIDAL 320Kbs- almost identical frequency response
QOBUZ 320Kbs vs. TIDAL 320Kbs - Delta of Spectrum
QOBUZ_16-44_vs_TIDAL_HiFi_02.pngQOBUZ_16-44_vs_DEEZER-HiFi_02.pngQOBUZ_16-44_vs_DEEZER-HiFi_01.pngQOBUZ_16-44_vs_TIDAL_HiFi_01.png
From what I see from the above pics, QOBUZ and TIDAL are offering about identical audio streaming services for the Lossless Quality and for the 320Kbs as well. Also, both audio streams seems to have more than enough "energy" to cover well above the audible spectrum, so I see no reasons why not to consider that both TIDAL and QOBUZ are offering top of the line streaming services.
For the 320Kbs bitrate, all three streaming services are getting about the same energy across audible spectrum and, in an well-conducted A/B test, I don't think we could spot any difference.
trl
trl
King of Mods
Iasi, RO
Spotify Very High Quality (320Kbs) - The most extended trebles from all the four streamers
Tidal Hi-Fi Quality (16bit, 44.1kHz FLAC files with a bitrate of 1411kbps)
Tidal Hi-Fi vs. Spotify Very High Quality
- looks like Spotify has a better trebles extension
Tidal HiFi (16bit, 44.1kHz FLAC files with a bitrate of 1411kbps)
