SimpleDumbPilot
- Joined
- Jan 19, 2021
- Messages
- 18
- Likes
- 11
This is not a major problem, I'm really just wondering if I'm the only one having it. I use Tidal and Spotify on my Android phone, my Windows 10 laptop, and my Node 2i streamer. The Spotify Connect functionality is pretty much flawless - I can send my session from any of those three devices, TO any of those three devices. The Tidal implementation seems way more buggy/poorly implemented. The weakest point seems to be the Windows desktop version of Tidal. For a while there, the desktop Tidal would actually see my Node 2i streamer. Then, suddenly, it just stopped seeing it. My Android phone has always been reliable though - I can always send my session from my phone to my Node, or take it back to my phone. Even when I take the Node out of the equation here, something's still not right - the Android implementation of Tidal does not see the Windows 10 version, and vice versa. According to the Tidal page of supported devices, this SHOULD work:
https://tidal.com/supported-devices?filter=tidal-connect&category=desktop
Is anyone else having the same issues?
FWIW the desktop workaround is to use the BluOS Controller desktop software. I'm using that on the same exact laptop, and it sees the Node 100% of the time. I was skeptical I'd use it much at all, but honestly it's a decent way to control the Node.
