Tidal artifact
Strato007
Hi people,
Could you check if something is wrong with my equipment?
During the whole track there are artifacts or little distortions, but more appreciate between 01.45 and 02.15 seconds for In my place - Coldplay song.
My setup that I am using now is:
LG G8x (quad DAC ESS)
Sennheiser HD650
USB player pro bit perfect mode (no eq) and Tidal direct app. I will try now with my iPhone and its dongle DAC
Doodski
Hi people,
Sennheiser HD650
Do you have a link to the audio track? Can you post the audio track on a download server so peeps can listen to it?
Strato007
Strato007
Thanks for answering, hope this helps otherwise let me know
https://tidal.com/track/128603
I have also tried with a VPN located in UK and it is the same issue.
It would be good to compare with a CD version or another HiFi platform...
Doodski
Tidal only permits the first 30 seconds of each track. So can't focus on the time interval of 01.45 and 02.15 seconds for In my place - Coldplay song.
Strato007
Strato007
Yes!!! You can hear it at 01.58 to 02.01
Bad recording anyways
