I did as you told me, I removed the right signal cable and put a resistor in and it still made that sound.
After that I removed the left cable and put a resistor in here too and it made it again, so with both signal cables removed from the preamp it still does.
This weekend I plan to take the big amplifier board down, on this occasion we'll also see what's on the back.
Now the only options are to replace all the capacitors, especially the ones near the power resistors which get hot and the high temperature can affect the capacitors.
An interesting thing is that the aluminum radiator is cold, on the other hand the two coils near the transistors you can barely touch, they are very hot.
If I keep taking it apart I could also replace all the transistors.I don't know how the preamp board communicates with the amp board because when it was in standby, to turn it ON, I had to touch the input connectors with an RCA cable and it turned on, the LED turned blue indicating the amplifier's ON status.
Above I have posted a video with the sound that I managed to catch, please try to watch the clip with sound.
Thank you
