Holy hell, don't you get perfect location of individual sounds with how you have it already? You'd think the processor could just balance the relative sound between them to precisely locate sounds inbetween the various speakers. I mean it does that already, so I'm surprised that's not enough speakers.thinking of installing furthermore additional JBL professional cinema 8330 mkI/mkII sidewall front wide LR and 8330A overhead surrounds of maybe up to
so i'm thinking additional JBL 8330A ceiling and re-plugging the other JBL as i may keep same positions or have maybe re-positioned so thinking of x17 on the ceiling ( maybe ? ) so it look like an " overhead sonic whole " , i have to figure out additional matrix decoders and a few more additional amplifiers in the amplifier rack ? as it would use the same ( DOG channels ) this may not happen for a month or two as i need get some hired hand due to health issues , it should only take a day to do the new install
well sound thou its still fabricated mixed recorded and real sound has no boundaries , the additional will focus additional newer channel/speakers with pinpoint positions ( theoretically )Holy hell, don't you get perfect location of individual sounds with how you have it already? You'd think the processor could just balance the relative sound between them to precisely locate sounds inbetween the various speakers. I mean it does that already, so I'm surprised that's not enough speakers.
Do you have less speakers than the various required standards for various cinema standards? I kind of feel that you've surpassed the minimum number required for the various standards? Or can you just keep adding more speakers beyond the accepted standards for better results?well sound thou its still fabricated mixed recorded and real sound has no boundaries , the additional will focus additional newer channel/speakers with pinpoint positions ( theoretically )
you should hear , " gravity " 2013 with five screen speakers , wow foley effects in some Lc Rc , directional dialog moving across the screen channels , additional ( Lsc Rsc ) i have to improvise and locate the speakers fairly close above the screen/ceiling between ( Lc and C and C and Rc ) a bit tricky , but i'm not downscale the JBL 4673A five screen ,
seven 7 screen speakers is a must
still there is additional sound that should be in-between middle of the room a sort of ( multi zone phantom stereo imaging ) with the below floor surrounds
i think you forgot about Dolby Stereo days i won't explain i would in a video if you watch my channel ? get a pioneer laserdisc player a Dolby Stereo CP200 and you'll be set up for star wars originals , 90% laserdisc here 10% dvd , 1% blu/uhd , streaming 0.1%Do you have less speakers than the various required standards for various cinema standards? I kind of feel that you've surpassed the minimum number required for the various standards? Or can you just keep adding more speakers beyond the accepted standards for better results?
Is it Atmos that is supposed to be totally flexible in pinpointing sound in a 360 sphere around you? Something in my head says that you can have as many speakers as you want with Atmos as long as you tell it where the speakers are? I know you don't like Atmos, but those are some vagaries I have in my brain about that when I was researching it re video gaming. (I don't know if all surround sound cinema standards let you have as many speakers as you want, I don't think they do).
You are one of the only people with a setup like yours to compare *theatrical THX* with reference laserdiscs against modern Trinnov algorithms. Any comments on the subjective experience?
As much as you don’t do streaming or modern movies, you should try Andor Season 2, Episode 1. The opening action scene is a superb sound demo.
I did try watching one your videos once and it went on for hours (I didn't watch it for hours), not something I could watch. I was just hoping for a few quick short informative nuggets of text information when I ask you questions.i think you forgot about Dolby Stereo days i won't explain i would in a video if you watch my channel ? get a pioneer laserdisc player a Dolby Stereo CP200 and you'll be set up for star wars originals , 90% laserdisc here 10% dvd , 1% blu/uhd , streaming 0.1%
I only saw this in stereo on my TV, albeit equilateral triangle with JBL 308p speakers and subwoofer, and I thought that was a fantastic experience sound wise, so I can totally see how good that would be on a proper surround system.best use of multi directional foley/effects and dialogue that i have heard/listened to in 45 years and i doubt there be another movie mix that will surpass " gravity " in the next 20 years , " gravity " is thee benchmark Dolby Atmos demo period , the whole 91 mins
there is a feature on the trinnov i not explored checked out to see what it sounds like or how or what makes it sound the way it does ?I did try watching one your videos once and it went on for hours (I didn't watch it for hours), not something I could watch. I was just hoping for a few quick short informative nuggets of text information when I ask you questions.
Right, so judging from the 3D diagram of speaker layout you tell Trinnov exactly where each of your speakers are located in 3D space, the exact measurements away from listening position & angles? It then will mix the contents of your surround movie into those speakers in the best way it sees fit to maintain the correct intended 3D audio positioning? So you can just keep adding more speakers and putting them where you want (& telling it their location) up to the max amount that Trinnov supports and Trinnov then does all the processing?there is a feature on the trinnov i not explored checked out to see what it sounds like or how or what makes it sound the way it does ?
Bl Bc Br , i get around to those later see what they can do and what else i can add onto it to expand it if its of any use for the front , maybe aliens mostly the drop-ship scene when its lowered into position and the air lock doors open lowered down and air lock doors closed sealed
aliens , THX/TAP Dolby Stereo in selected JBL professional THX cinema
i have no idea i not ( tried any of those as of present/yet ) when i have the time and give it some bias listening to see what i think or maybe it only supported by certain digital codec ? or maybe manual matrix control for Dolby Stereo AC-3Right, so judging from the 3D diagram of speaker layout you tell Trinnov exactly where each of your speakers are located in 3D space, the exact measurements away from listening position & angles? It then will mix the contents of your surround movie into those speakers in the best way it sees fit to maintain the correct intended 3D audio positioning? So you can just keep adding more speakers and putting them where you want (& telling it their location) up to the max amount that Trinnov supports and Trinnov then does all the processing?
I was just trying to increase my understanding of the "framework" of how Trinnov worked. Are you saying you don't know how it works, or of course you know how it works surely, you're tweaking it to the nth degree right.i have no idea i not ( tried any of those as of present/yet ) when i have the time and give it some bias listening to see what i think or maybe it only supported by certain digital codec ? or maybe manual matrix control for Dolby Stereo AC-3
getting slowly understanding with the unit , it is computer complex processorI was just trying to increase my understanding of the "framework" of how Trinnov worked. Are you saying you don't know how it works, or of course you know how it works surely, you're tweaking it to the nth degree right.
