Strompel
- Joined
- Jan 22, 2019
- Messages
- 9
- Likes
- 8
Hi,Hi!
Does anyone know if it is possible to choose which output is active - TRS or RCA - or are both active at the same time?
They are both active.
Hi,Hi!
Thanks. And you can switch between direct output, or volume control?Hi,
I have a dual 9038q2m dac too. And they are both equal in quality when level matched
Yeah if you are not going to use Bluetooth I would say that the e50 is hard to beat. While the mqa licensing seems to be looked down upon in this forum; I have now had the chance to experience it and can say that it definitely does sound better versus standard streaming (like Spotify, YouTube music, Tidal standard / cd quality, Amazon music streaming). I found it apparant in classical music the most.I didn't feel any 'big' difference between the two. It would be wiser to say that there is no difference in listening to music. There's a limit to human hearing, so we can only talk about what subtle differences there are. Limitation.
The sound of the E50 which I felt is a little bit cleaner and a little bit more layered, but it's just a subjective feeling, and I think it's hard for most people to feel the difference between the D-6 and E50.
The E50 has MQA unfolding function and does not have Bluetooth function. It seems a little wiser to note these differences. (Aside from the issue of whether MQA is the right way to do it)
Yes you can select that.Thanks. And you can switch between direct output, or volume control?
Hi, Someone had added a link to an updated owners more complete manual a while back and I was able to open and view but is no longer available it says. Any help getting a line on a full(er) users guide? Thanks!
Hi, Thanks yes I’ve seen that but I still don’t see the filter explanations in English as I had before, Am I missing something?D-6
Foshan ShuangMuSanLin electronics Co., LTD. founded in 2009 which located in Shenzhen, China. And our branch company VMV Technology(HK) Company Limited registered in HK in 2013. Our company is specialized in the audio DAC, stereo headphone amplifier, power amplifier, and with own R&D...www.smsl-audio.com
The official website is still not updated, you can refer to the file in my link, it is updated.Hi, Thanks yes I’ve seen that but I still don’t see the filter explanations in English as I had before, Am I missing something?
I have changed the batteries and other functions of the remote are working normally. It’s only the volume control that isn’t responding.Try changing the battery in the remote.
I think Pr1 is the only mode that allows volume change.I have changed the batteries and other functions of the remote are working normally. It’s only the volume control that isn’t responding.
Could any users of the D-6 advise if the knob on the DAC changes volume (and if so, how)?
(The User Manual is inadequate.)
Thank you! Fixed.I think Pr1 is the only mode that allows volume change.
How?Thank you! Fixed.
Thank You!Sorry the attachment was too big I had to use an external linkD-6说明书91x133mm.pdf
1 file sent via WeTransfer, the simplest way to send your files around the worldwe.tl
