leafygreen
- Joined
- May 20, 2020
- Messages
- 7
- Likes
- 1
Spending more time in my living room these days, I decided I wanted to delve further into music and subscribed to Tidal. I was about to buy a dragonfly dac on recommendation from a family member. I thought I would read up a little first to see if I could find any cheaper options and then I stumbled on this site. I've been reading through the reviews and discussions for days and it has been an eye opener - thanks and hats off to the reviewers and commentators here. I had suspicions about some of the creative use of adjectives in equipment reviews out there, but had no idea it was quite so 'chimerical'.
Anyway, based on the excellent DAC comparison tool, I've narrowed down to two cheaper well-rated DACS as captioned. I'm playing from the Tidal app on an iPad, through a 3.5mm->RCA cable, plugged into a nice old NAD amp and B&W speakers. I like a bit of cable length (e.g. 2m) between iPad and amp, for couch control. With the comparable technical ratings in mind, would anyone recommend:
(i) SMSL Sanskrit, with it's own power supply, sitting next to the amp, with a short RCA connecting it to the amp, and a longer (2m) lightning->USB B cable running to my iPad; or
(ii) the more portable HIDIZS S8, plugged in close to my iPad with a short digital connector (as per design) and keeping the longish (2m) 3.5mm->RCA to get it to the amp?
It seems the technical indicators of both DACs are similar and excellent, but I'm wondering if the power and cabling setup as described above might be a factor, or not that important.
