I've made my own a few times out of rectangular or square copper stock. Cut to length, drill the needed holes in the right places, in the right orientation. I always twisted and mechanically joined the tails and held the connection with 4% silver solder.
I've used 1/4 3/8 drilled round stock as a bus bar too. You can use zip ties to secure the bars or round stock to a
turret board
for easy soldering and then securement. Turrets are also one of the best and cleanest ways for a point-to-point layout.
Below is in a separate box:
You can see how easy it would be to add a turret, a wire, a component, or remove one. It was also pretty easy to add 2 more boards in the
Harp Box One to the bottom of the box and one to the cover for the box. The TB is held in place by blocks at either end and can be slid out for vice work. You can see how convenient it would be to build a 2, 3 or 4-way point-to-point. Using 3 boards, with the middle board having 2 sides and clearance. Use Hot glue or through screws for the top and bottom standoffs (I use both screws and epoxy).
I've built quite a few using copper and silver turrets. Easy to add inline passive L-Pads, component swaps, test ports, and quick connects
Poor Man's CR/USPS in May/1999. "
Harp Box" I made about 30 boxes for friends and folks that liked them.
These were designed as external passive crossovers with silver turrets. I eventually added components to the top and bottom of the board for both mids and highs, for an LS of 6 ea. Neo 8" planars and 10 ea. AC G3si ribbons.
Just a thought or two, ay?
