Mean & Green
- Joined
- Jan 6, 2022
- Messages
- 362
- Likes
- 509
Can anyone explain this problem to me?
I have inserted a Schiit Loki tone control into my system via my NAD C326BEE integrated amps ‘tape monitor’ loop. I can use the Loki as I want with any source by simply engaging the monitor function on my amp. Now most of the time I do not require the Loki so leave it switched out of circuit, great right? Well… I have noticed significant audible distortion with my system when the Loki itself is switched off even though it shouldn’t be in circuit due to not activating the ‘tape monitor’ loop.
I have noticed this in the Loki instructions. (See attached image).
Leaving the Loki on even when not in use and even when ‘tape monitor’ is off or on, all is fine - but if I switch the Loki completely off I get distortion which gets worse if ‘tape monitor’ is activated, but distortion is still there even when ‘tape monitor’ is off. How can switching the Loki completely out of circuit via ‘tape monitor’ being off still have an impact?
I understand I can just switch the Loki on even when not using it, but I don’t see why I should have to when it should be completely bypassed via the ‘tape monitor’ switch.
Can anyone explain this to me? ‘Tape monitor’ on should include the Loki in the chain. ‘Tape monitor’ off should be completely bypassed so how can it have any effect whether the Loki itself is on or off? It makes no sense to me why any part of the Loki matters when ‘tape monitor’ is off.
