bennybbbx
Good tip! I am considering to use the RCA output on my preamp. My poweramps are the Stageline STA2000 and that also accepts RCA inputs. I check that the RCA has 10 db less output than the XLRs. That could already be a a good option too.
No, dont use RCA if youn can. When you connect a RCA output to t.racks dsp you loose 20 db dynamic because the dsp have only a fixed gain that do ~+6 db as full sample (FS). RCA have only -10 db. and when you connect the mini DSP to RCA in poweramp make the signal 16 db louder and so noise can hear from dsp
did you currently hear noise even when you use studio levels ?. if so, your volume knob is too much right. when the knob is in such a position that the amp can play FS with 115 db then of course you hear noise of the dsp.
RCA use line Level. you can see on this diagram. to get best dynamic your input should produce ~+6 db. and your amp need produce with +6b the volume you want hear. if you are 1 meter away 115 db kill your ears but this 2400 watt amp can do it. and when you are more away then you hear less noise. maybe this diagram show more clear what i mean
