- Joined
- Apr 24, 2019
- Messages
- 1,501
- Likes
- 2,822
Please folks, this is a good resource. http://hyperphysics.phy-astr.gsu.edu/hbase/electric/miccur.html#c1
It's Just Wire!
Michael Fremer recently posted some files to compare: recorded through different high end speaker cables. People in the comments thread saying they hear obvious differences. There was a problem with the original files (some L/R swapped, also difference in loudness) and someone in the thread I think fixed them and normalized them.
FWIW:
https://www.analogplanet.com/content/its-just-wire-1#comments
BothWow, it took some work to be either that dishonest or that incompetent.
Also I always thought insertion loss is usually frequency-dependent, not flat across the entire frequency range.
As far as the wire is concerned, audio frequencies are practically DC.
Strictly speaking, that tells us nothing at all, but we can be generous and assume the output impedance is given in ohms. The other numbers are useless without knowing the conditions under which they apply. The maximum length depends on cable parameters and acceptable signal degradation. Maybe they mean that the maximum length is 1360 ft if loss is to be limited to 0.1 dB at 20 kHz. If so, it still only applies to certain cable types, which they should have specified. Proper interface specs rarely include an explicit maximum cable length, instead bounding the signal degradation at the far end. Where length limits exist (Ethernet, USB), they are determined by propagation delay, not signal quality.
Although latency/propagation delay is a limitation of some interfaces, length limits due to signal integrity occur quite frequently in the high-speed serial data and RF worlds...
Yes, there is a practical limit, but I've rarely seen it specified explicitly. HDMI, for example, doesn't specify a maximum length. If you can somehow make a cable that delivers the required signal quality after 100 metres, that's allowed.Although latency/propagation delay is a limitation of some interfaces, length limits due to signal integrity occur quite frequently in the high-speed serial data and RF worlds...
Indeed. High speed serial and RF. Not audio.
I think we're saying the same thing.I agree with you. I don't know anything about HDMI (I do have the spec downloaded, someplace, but I'll take your word for it). Mostly in my world (currently PCIe/SAS/SATA) the specs are not explicit but rather reflected in specified max/min Rx/Tx signal levels and various insertion loss specs. We know what length cable was targeted in developing the spec but it is not specified explicitly. Sometimes there is a graph that says "don't be worse than this" but again an actual length is not specified. Part of that is because cables are not the same in the RF world; one 6 m cable might work fine, and another fail, and when you measure them the loss difference is obvious. Then there are those who have an extra 10+ dB loss on a board and wonder why a cable that works on one system with 3 dB loss does not work on another with 15 dB loss...
That's pretty expensive and doesn't even seem to be proper coax.This SKW RCA interconnect has got good user reviews on Amazon and looking good for the price.
Anyone used it here?
