我不认为 DT880/600 是一款顶级耳机,但它具有温暖而“闪亮”的高音,以及很高的(伪)细节感,而且听起来不会过于“尖锐”。
- 没人能告诉你DT880/600搭配任何耳放会给你带来怎样的感受 。
要想让它发出大音量(它并不擅长超大音量,拜亚动力耳机都如此),你需要一个高输出电压的耳放。120V
的内部电压轨(+/-60V)只是个噱头,实际输出电压只有24Vrms,也就是68Vpp。- 单端输出和平衡输出之间不存在“音质下降”。DT880
耳机只能用于单端输出,除非您对耳机进行改装。
由于其高阻抗特性,即使使用长卷线(专业版),也不会出现串音。- 无需担心。功放的声音不会“单薄”。
功放的输出阻抗也不会影响DT880/600的声音。
如果想要开到非常大的音量(失真会非常严重),你需要15V的输出。
这意味着任何能够在300欧姆阻抗下输出0.7W功率的功放都可以做到。
你可能会超过DT880/600额定功率的4倍,但这在听音乐时不会造成问题。E2x2
的输出只有6V(600欧姆阻抗下55mW),而DT880/600的额定功率为100mW(连续功率)。XE
的输出功率可以超过DT880/600额定功率的20倍,如果意外达到这个功率,可能会烧毁驱动单元。
与您已拥有的相比,以下是部分内容。
20美元左右的入耳式耳机对我来说效果不错,奥地利Austrian Audio的廉价舒适耳机也很好用。不过每个人的耳形都不一样,所以耳机的佩戴感受也会因人而异,就像不同房间里的音箱效果也不同一样。说真的,别完全相信我或者任何人的推荐——你只能自己去尝试。至少,如果你在比较之后觉得不太满意,还可以退货退款。
I use ie600 now it have good shape for my ears$20 IEMs work well for me, as do cheap but comfy Austrian Audio 'phones, but everyone has differently shaped ears so 'phones in particular will vary from one user to another, like speakers in different rooms. Really though, don't take my or anyone's recommendation - you can only try for yourself. At least if you are not super happy when comparing, you can send them back for a refund.
I'm pretty interested in the Phonitor One to check out their speaker simulation. So if you get one let us know your thoughts.Hey folks,
I'm at that dangerous point in the hobby where I'm staring at the "Checkout" button and need a sanity check from people who've actually heard this thing.
Current stable / context:
I've been running a Topping E2x2 as my DAC and general desktop command center. It's honestly way cleaner than it has any right to be for the price. Headphone-wise, I'm usually rotating between an HD 600 (daily driver, cozy vibes) and a DT 770 Pro 250Ω (when I need to not annoy my partner). I also mess around with a HE400se and a Moondrop Para 2 when I'm in a planar mood, but let's be real—the Para is a hungry little monster that probably wants a speaker amp.
The Plan:
I've got my eye on a Beyerdynamic DT880 600Ω. I know, I know, it's the "vintage" choice, but I want that specific, lean, hyper-detailed treble cannon experience. I'm not looking for a warm, tubey hug for this one—I want the reference.
So the question is the amp. I keep coming back to the SPL Phonitor Mini. I know it has the 120V rail thing, I know it'll do 1W into 600Ω, and I know it's dead neutral.
What I want to know from owners:
1. The "Boring" Factor: With the E2x2 being already very clean, and the DT880 being... well, a DT880... is the Mini going to make me feel like I'm analyzing a spreadsheet instead of listening to music? Or does that "Phonitor Matrix" crossfeed actually make it more engaging?
2. Single-Ended Life: I see it's SE only. Coming from a balanced setup on the planars, am I going to miss anything significant with the 600Ω Beyer, or does the high impedance just laugh at crosstalk concerns anyway?
3. Is it truly "Endgame for High-Z"? I don't want to buy a $500 amp and then six months later be browsing used Bottlehead Cracks because the Mini is too sterile. Should I just go straight to tubes for the 880?
Appreciate any real-world takes. I'm trying to avoid the slow climb up the SPL ladder to the Phonitor XE.
Overall I think @solderdude hit the important points, the SPL Phonitor has much more power than you need for those headphones.
I think crossfeed is a good feature and I personally use it with my headphones, but you do not need to spend $500 to get crossfeed, especially if you listen with a computer as source. The DSPi (check the other thread) has crossfeed and EQ, etc. for ~$5.
I would also not worry about the amp having a "boring" or "interesting" sound. Most amps should have no character whatsoever, a great deal of the discussion of the tonal characteristics of amps is due to placebo effect.
You may want to upgrade the amp so you can max out the 880s but I would simply focus on finding an amp with adequate power.I may buy Phonitor One during the winter vacation. I may also buy Schiit Jotunheim 3 to drive my Planar Diaphragm HeadphoneI'm pretty interested in the Phonitor One to check out their speaker simulation. So if you get one let us know your thoughts.
I may buy Phonitor One during the winter vacation. I may also buy Schiit Jotunheim 3 to drive my Planar Diaphragm HeadphoneI wasn't planning to use this with a computer, maybe I'll see about trying it.
