Everyone uses AI to ask questions and/or create images etc, but I wonder if others like me used AI to research a topic and ended up buying something based on its advice? Can be audio related or other stuff. And if it was a good advice or bad? Any AI: ChatGPT, Gemini, Claude, Grok, whatever.
I start with 2 examples that I "discovered" based on AI.
minidsp Flex HTx was not on my radar at all when I was researching for an AVP to replace my old AVR in my HT setup. Of course I know the brand and its most famous products, but particularly the Flex line flew under my radar for some reason. After chatting back and forth with AI for my use case, preferences, budget, limitations, etc I ended up buying the Flex HTx and it worked like a charm (given that you pair it with an Apple TV 4k, which I knew and did). This one worked alright.
The others are not audio related.
I have an old mini ITX computer that I wanted to upgrade its CPU to the maximum the motherboard would accept for light gaming for the kids. It suggested me a specific model (5775C) which I would never guess or have researched, I ended up buying and it was indeed a good call. Then I needed a low profile cooler for it, and it recommended a Thermalright AXP90-X47. I am still about to receive it, I think it was a good call because it filtered hundreds of options out there and gave me what apparently fits my needs, budget and limitations. I assume another successful purchase suggested by AI that helped me narrow my choices.
Maybe I got lucky? Does any of you ended buying something clearly wrong because of bad advices from AI?
