solderdude
On headphones the 'stones in my passway' recording sounds great to me. I don't care if its cognitive bias or not and if it is then I am glad that works for me.Almost certainly cognitive bias is the reason you perceive 'great sound' from such recordings.
It has to be played a bit loud though due to the dynamic range and brings a 'live-feel' for me.
Measuring/seeing 108dB peaks, when I dial down the volume to 102dB peaks it still 'works' for me but below that it looses 'charm' (DR around 13)
Quite a few studio recordings also sound great to me, where compression is used correctly. Don't care if its cognitive bias or not either.
Simple certainly is not always best and the idea that 'simple is always best' is a typical audiophile myth been proven to be incorrect in most cases.'Simple is best' is a very common and understandable bias, but it should be tested and, in this case, it fails.
Carmen Gomes recordings may be a fail to you but there is taste and preference too so what may be a fail to you or some others may not be so for someone else.
