I don't know about all of that. I've done a little recording. Two microphone vs multi mike really is one of those things where you don't need to blind anyone as there is enough difference. I have done that test with people blinded however with level matching (which is a sticky wicket all on its own), and letting people decide which they like. Yes, always preferred the multi-mike version. I don't, but then even blind you always know which is which you are listening to. Now I've never tried to get two versions to sound the same and compare, but then again why would you?
The other test I've done is uncompressed with a little compression. A little compression with a little more compression. A little more compression with even a little more compression and then even a little more vs even more compression. Done this with both two mic and multi mike recordings. Compression was preferred every step of the way by everyone I had listening. The final step was the highest level of compression vs none. Everyone wrinkled their noses at how bad one of them sounded and preferred no compression. My highest level of compression was lower than is your typical squashed commercial recording. No limiting for instance. So what do you make of those results?
