Tom67
One factor missing from the objective approach is that of "perceived" value". There is nothing objective about it. Yet it swirls around in the brains of most consumers when they weigh the value of one product over another. Take Amirm's revue of the Klipsch RPM600M. He considered the specs to be lousy out of the box. But then consider the conclusion here.
"Out of the box, the Klipsch RP-600M throws out the rule book, thinking that if you just sold boosted lows and highs and leaving mids behind is a good idea. It is not. Objective and subjective testing shows this to be a horrible choice ranking the speaker as one of the worst I have tested. Dial in some simple EQ though and the speaker transforms into a beauty. The "horn" is actually not a horn but a waveguide that is doing its job to provide uniform off-axis response allowing one to EQ the mid-range dip".
"Since I have to score the speaker as designed, it gets my worst rating of "stay away." If you have ability to EQ, and you better do if you are hanging around this forum, then you have a good offering."
So, I bought this thing for a small spare bedroom system for about $300. I spent a few minutes doing the suggested equalization on a WIIM amp. So now I agree with Amirm that I have a good sounding set of speakers. Now I could have chosen a set of Revel 126 bookshelf speakers for $4,500 which would probably test better. My guess is that they would also sound like a "beauty". But you can buy 15 sets of the Klipsch for one set of the Revels and provide the gift of music to your friends and family.
So, to respond to the OP, I am suggesting at least two subjective factors that may be of paramount importance and there are no doubt more. 1. There is a question of value inherent in product. 2. Some objective issues can be addressed by simple measures like equalization, speaker placement, room acoustics etc.
Klipsch RP-600M Speaker Review
This is a review and detailed measurements of the Klipsch RP-600M Speaker Review. I purchased them from Amazon a couple of weeks ago. The current cost on Amazon is US $629 including Prime shipping. I however found a refurbished one for $450 I think. It looks brand new in the box though...
www.audiosciencereview.com
