"Things that cannot be measured"
I wonder how close an IR of your listening room combined with a spinorama gets you? I mean I feel I can read the data well enough to not only be able to compare speakers but also to understand to a large degree how they will sound in my space. I mean FR, directivity, resonances… and once I combine that with knowledge of the physical characteristics of the room and likely speaker placement, how much of a surprise can there be?
No one in my opinion can "accurately" translate loud speaker measurements to the actual listening experience in an unknown listening environment. Speaker measurements are important for consideration but not the end game. The end game is the speaker room interaction and that is very difficult to fully predict because every room is very different. Unlike electronics where measurements get you all the way home. I believe Amir has said that in the case of speakers measurements only get you about 70% home, unlike electronics.
None of which changes my statement in any way. They are still very useful.
Anechoic measurements give you an excellent indication for preference regardless of room.
Good measurements (wide even directivity) also indicate speakers that will be easier to correct in room with room treatment and/or DSP.
What's not to like?
True that every room is very different. OTOH modern speaker measurement techniques like "spinorama" that closely detail radiation patterns quite well can tell you a LOT.
True, not fully. But they beat every other method (other than blind testing in your listening room!) by a wiiiiiiiiiiiiiiiiide margin
Of course, that's why every serious designer has been using these techniques for decades, but many of us amateurs lose focus and forget that speakers are meant to be listened to in real rooms.
Roy Allison was well aware of this and designed speakers with this condition firmly in mind. I am sure if he was with us today, with our improved measurement techniques, he would offer us even higher performing home loudspeakers.
the only way to really listen to speakers in order to evaluate them is to do so under controlled, blind conditions. are you seriously chiding us for not doing that? if so, I'm afraid your disappointment will be perpetual.
you can't be arguing that sighted listening is effective for speaker evaluation, right?
No, I am arguing that at the end of the day, it is time to stop evaluating. Life is better when we learn to enjoy the hard work of our many brilliant speaker designers!
the day hasn't ended. people need to buy speakers every day. people need to identify the cause of audible issues in their speakers every day.
nobody here is advocating constant evaluation of speakers we already own and enjoy. why object to something that isn't even on the table?
Search me...
It's your objection: "I am arguing that at the end of the day, it is time to stop evaluating."
It's a baffling argument since it's against...nobody and nothing in this thread. There is nobody arguing that we should perpetually evaluate our speakers and not listen to and enjoy them. It's reminiscent of the transparently bad-faith subjectivist argument that measuring somehow precludes pleasure. It does not. It increases it.
The objective view is not to replace subjective view but to inform and guide it.
Not for speaker evaluation no, but for personal speaker selection yes. How you feel about the looks of a speaker, as you know, will impact your opinion of the sound. That's why you have a blind test, but consumers are trying to select a speaker they "think" sounds the best. Anything that affects that is fair game for consideration. They are not concerned with evaluating them in the strict scientific sense. I don't believe even a scientist would purchase a speaker they believe sounds inferior, regardless of the reason, because it measures better. Cheers.
Reactions: STC
I'm baffled too... baffled why we waste our time in these circular arguments. Obviously my mistake.
I think there's something here, but a simple IR will include the directivity of whatever sound source was used to create the IR... which might be fine as long as it was an omni source (starting pistol, balloon pop, spherical speaker array) ... I guess if you took two omni IRs where you intended to put the speakers and then did some fancy processing to imprint the directivity from the spinorama / polars onto the IRs, then you could conceivably simulate the in-room sound of different speakers and listen to it on headphones...
Someone who doesn't have a toddler should try this and see what happens.
I guess to test it you'd need two sets of pretty different speakers, then compare the subjective difference in the simulations to the real-world in-room difference?
Do you generally consider these: breakup, HF radiation pattern, and losses, to be the main audible factors, as far as differentiating one material from another when other aspects are controlled for, or may not important to a particular build? This seems implied above, but I wonder if there is a more complete set, or other relevant factors you would want to share.
Bottom line would be: If the moving parts move exactly the same (think a dense grid of points moving in 3D space) in all details and under all circumstances, and have the same geometry, then the drivers will sound the same (all other aspects -- motor, alignment, etc -- being the same). If not, they may or may not sound different.
This does NOT depend on the material as such. It depends on the physical properties of the whole construction. You sure could make a paper cone that behaves like a typical soft polyprop.
Can you think of a speaker that measures well but sounds 'inferior'? How could such a thing exist?
Measurements and human perception and preference are different things. I can clearly imagine a speaker that measures well and is perceived as sounding inferior to another, also well-measuring speaker (using the typical, usually incomplete set of measurements). For example, one speaker might sound "bland" to someone, the other "exciting" without any clear tells for that in the measurements (I'm not talking about trivial stuff like emphasized treble and such). The next guy might perceive those two speakers as "neutral", and "over-detailing", resp., and prefer the first one.
I'm finding it hard to envision a situation where the impressions would be so different without there being a 'tell' in the measurements.
Not inferior just measurements may not meet real world audiophiles taste.
'Inferior' was the specific word used and was what I challenged.
We know that it's highly unlikely that audiophiles would continue to prefer their expensive, poorly measuring, elaborate back-story speakers in a controlled comparison.
