I wouldn’t take it to heart there are contributors here who actually know stuff, every day for me is a learning experience.
Cone material isn't directly 'heard' so you can't blind test it in isolation. Rather its properties contribute to behaviour of the driver - its sensitivity, and break up frequency and pattern for example.howardg said: I hear differences in how different cone materials present sound,
No.
Is there a generally accepted norm on ASR that cone materials mostly sound the same, blind and level matched? Or have these tests been performed by others?
You are too kind.Also, I suspect that you did not try to be "mean"
I think what Newman is trying to say is that there is already a large body of work in psychoacoustics that are not consistent with you claims, so you should educate yourself before making such claims. More generally, contrary to the lay belief of science advancing in huge quantum leaps that rely on one-off Eureka discoveries made by geniuses, much of advancement in science occurs piecemeal through incremental work that builds on huge bodies of existing work.Many here know a lot more about audio science than I do, but where do you get "never occurs to perception scientists and invalidates everything"? Is that really fair/accurate?
Yeah, I really wasn't trying to be mean (but I also wasn't trying not to be, I guess?)I have changed my outlook on your comment. One reason is that I think that there are not that many here who might like what I have to say, due to my lack of knowledge, and possibly because of the way I present it. I think that you are probably generally correct that there are likely not that many here that want to hear about my opinions. It was just difficult to hear it that way before. So, I have let go of some of my personal need for validation/acceptance. Also, I suspect that you did not try to be "mean", and were possibly mostly meaning to be logical and direct.
One can find terrible and excellent examples of all the typical materials, hence I conclude that design and implementation are so much more important than material that it can drop out of the buyer’s decision process.Is there a generally accepted norm on ASR that cone materials mostly sound the same, blind and level matched? Or have these tests been performed by others?
There is a view that tonality is what defines how the tonality of a speaker sounds - and that is shown by frequency response measurements amongst others - regardless of cone material.howardg said: I hear differences in how different cone materials present sound,
No.
Yes, material affects the sound. So do many other aspects of the driver, in many cases more so than the material.howardg said: I hear differences in how different cone materials present sound,
No.
There is also a view that you can't know what is specifically causing your perceptions of differences between speakers. Partly - in the case of cone materials - because you can't listen to speakers that are identical other than cone material, and even if you could - listening sighted would invalidate any perceptual assessment.
There is a reason blind test methods are used in proper evaluations involving human perception.
Material itself has no sound, only the specific embodiment of a construction has physical properties that result in superimposed general character on top of what the voice coil delivers to the cone/dome. If that character is subtle and well-controlled (and that's what most designers are striving for) then, in the end, "different materials sound the same".howardg said: I hear differences in how different cone materials present sound,
No.
I think so too it affects how you design the whole speakers and it's crossover . So by necessity you cant really compareCone material isn't directly 'heard' so you can't blind test it in isolation. Rather its properties contribute to behaviour of the driver - its sensitivity, and break up frequency and pattern for example.
As for that, I have both the metal cone and bamboo cone version of one and the same Tang-Band driver design (W4-1337 and W4-1320). When EQ'd to the same target (the HF region is different, and some T/S at LF) as "good as possible", they still do sound different.... as they simply cannot be EQ'd to the same target because the breakup is different and thus HF radiation pattern, and losses are different, too. When used as a midrange up to 2kHz, the differences fully disappear, no way to tell them apart.I think so too it affects how you design the whole speakers and it's crossover . So by necessity you cant really compareas the resulting speaker is not the same
Sounds reasonable to meAs for that, I have both the metal cone and bamboo cone version of one and the same Tang-Band driver design (W4-1337 and W4-1320). When EQ'd to the same target (the HF region is different, and some T/S at LF) as "good as possible", they still do sound different.... as they simply cannot be EQ'd to the same target because the breakup is different and thus HF radiation pattern, and losses are different, too. When used as a midrange up to 2kHz, the differences fully disappear, no way to tell them apart.
Do you generally consider these: breakup, HF radiation pattern, and losses, to be the main audible factors, as far as differentiating one material from another when other aspects are controlled for, or may not important to a particular build? This seems implied above, but I wonder if there is a more complete set, or other relevant factors you would want to share.As for that, I have both the metal cone and bamboo cone version of one and the same Tang-Band driver design (W4-1337 and W4-1320). When EQ'd to the same target (the HF region is different, and some T/S at LF) as "good as possible", they still do sound different.... as they simply cannot be EQ'd to the same target because the breakup is different and thus HF radiation pattern, and losses are different, too. When used as a midrange up to 2kHz, the differences fully disappear, no way to tell them apart.
How do you control for other factors?when other aspects are controlled for
Not sure if you mean how do I control for factors; or some other meaning?How do you control for other factors?
No one in my opinion can "accurately" translate loud speaker measurements to the actual listening experience in an unknown listening environment. Speaker measurements are important for consideration but not the end game. The end game is the speaker room interaction and that is very difficult to fully predict because every room is very different. Unlike electronics where measurements get you all the way home. I believe Amir has said that in the case of speakers measurements only get you about 70% home, unlike electronics.Just because you can't understand the measurements doesn't mean they are not very useful to those who can.
Well put.No one in my opinion can "accurately" translate loud speaker measurements to the actual listening experience in an unknown listening environment. Speaker measurements are important for consideration but not the end game. The end game is the speaker room interaction and that is very difficult to fully predict because every room is very different. Unlike electronics where measurements get you all the way home. I believe Amir has said that in the case of speakers measurements only get you about 70% home, unlike electronics.
True, not fully. But they beat every other method (other than blind testing in your listening room!) by a wiiiiiiiiiiiiiiiiide marginthey do not fully describe how a speaker will sound in your or my listening room.
