THIEAUDIO HYPE 10
Milo1968
Has anyone own or had a chance to listen in detail.
I'm interested in these and my ideal iem is good deep bass that is excellent in timbre, quick response, clean, mids That are neutral but detailed without sibilence. Treble which doesn't spike but good clarity and detailed
Just get hype 4 its cheaper and sounds pretty much the same.
There is nothing magical in this expensive iems.
You can even consider kiwi ears ke4 it's similarly tunned and even cheaper
Thanks for the info! I just got my Kiwi Ears KE4 :)
It's good IEM, it's safely tunned
If harman tuning is too shouty/spicy around ear gain, KE4 could be a good alternative.
Right, I haven't spent enough time with it, probably less than an hour, but initial impressions is quite positive :)
The 3kHz ear gain is less than typical Harman tuned IEMs. Less shouty and sounds more correct to my ears.
The bass slightly north of my balanced target, not too much, quite a fun and satisfying bass. But not as tight and textured as I would like. A bit on the boomy side.
Overall still a nice tuning, especially on vocal.
