Oh come on the pot stirring trio does this every other week i thought you would be used to it by nowBut apparently mine aren't? I post a ton of measurements but you and john focus on one number and complain that you did that?
Some posters here seem to have a mission to just complain. Is it your position that consumers would be better served with no measurements as opposed to having mine?Yes he does. He knows very well what he is doing, which cannot be said about many posters here.
Our posts crossed. Well said.Oh come on the pot stirring trio does this every other week i thought you would be used to it by now
I did one continuous test and blew up an amplifier. Such a test doesn't represent music listening so I can't defend it either.I previously had two Behringer A800 amplifier, when I bench tested them I found I could achieve the same power that Amir did but only for about 10 seconds at which time a limiter kicked in and power output dropped. Maybe it was a design change from the amplifier that Amir reviewed but it has certainly made me a bit wary of ASR power sweeps
I am just estimating but I think it is one minute from start to finish. About 5 to 10 seconds are under heavy load. Timing is variable and depends on how stable thd+n readings are.Understood. For my own curiosity, how long does that power sweep test take?
amirm, What amp did you use to test the speakers? AHB2?I am just estimating but I think it is one minute from start to finish. About 5 to 10 seconds are under heavy load. Timing is variable and depends on how stable thd+n readings are.
I am not here to assess reliability, nor is any other review site. You don't even know the ambient temp for their tests. Or level of airfliw.Yes but a continuos test tells something about the design competence and reliability.
For what? Measurements or listening tests?amirm, what amp did you use to test the speakers?
Measurements.For what? Measurements or listening tests?
I would like to get back to topic , it would be interesting to see this measured for sure
Neither. I use a Behringer pro amplifier. The amp needs to be powerful, run cool and reliable for hours on end during testing. FYI its frequency response is compensated to flat by Klippel analyzer.Measurements.
Mark Levinson or AHB2?
I also do preconditioning during warm up. I actually post this result to the extent performance varies. I see no point in continuing to "condition" an amp once its performance has stabilized:JA is always doing a 30 min preconditioning at about half maximum power, now maybe at 1/8 power.
And lower heat output.I hope it is. More likely to be in my price range if it is - and the performance will be excellent.
When listening test, use PA5?Neither. I use a Behringer pro amplifier. The amp needs to be powerful, run cool and reliable for hours on end during testing. FYI its frequency response is compensated to flat by Klippel analyzer.
In near-field and recently, yes. Before that, I used my Purifi reference design for that use. The main 2-channel system is powered by Mark Levinson reference amplifier.When listening test, use PA5?
