The W&F Analyzer Project, Uberrimus
There is unfortunately, that I know of, not a better replacement belt for the Linn Axis (or LP12). I had hopes for the Thakker belt but the 0.5 and particularly the 1.0 Hz component increased significantly. I also think the Thakker belt was slightly longer than the Linn Belt. Values below are for just visual centering without the USB camera, so the 0.55 Hz component is a bit different. The point is though that the 0.5/1.0 Hz is huge on the Thakker belt. So no cheap alternative yet.
Thakker belt, new:
Original Linn belt 3 years old:
That was A horrible belt… most 3rd part belts are
I've tested a cheaper and even worse though, posted in the "Fun thread" in February 2023. It was the same time I acquired a new Linn original belt (the old belt was significantly stretched when comparing them).
At least the Thakker belt had the same dimensions (1 mm thick, 5 mm wide) as the original, but it might be some mm longer. So I had hopes for it. But I do not think it is the same material and compliance and it seems to be poor.
Now what is the lifespan of a belt? Should I buy a new Linn belt for €80 and test against the 3- year old one? If no difference I can just save it until it is time for change. I think Linn says 5 years.
Now for something suprising. The old Linn belt vs. a completely new original Linn belt. Perhaps there is a first timer for a "run-in"? My hope this is an original Linn belt...
The old belt:
The new belt:
Old belt again:
Spent an hour to more precisely adjust the inner chassis to align the pulley with the inner platter. Running in the new belt like this and I will measure again after a months regular use.
Taking a break for a couple days from this. Hung out with a friend on Thursday who's in the industry, and one of the outcomes was the idea to simulate W&F profiles for listening tests so people can understand their sensitivity. I made a script that uses the 16 peaks from the FM demodulated plot data from wf_core to build a profile. You can then use that profile to apply simulated wow and flutter at different DIN metrics to audio files.
Here's an SP-10MKII FG profile simulated from 0.05% to 1.5% in 16 increments. The test is to choose which is the reference file vs. the higher W&F files.
I thought I saw the spectrum of the FG in this thread, but now cannot find it. Will try a bit more serious to see my limit. A steady synth tone may be more audible than a piano that may contain some wow in sustain.
Here recorded 1000hz track from Technics SFC TR-100,, simultaneously as I made Shaknspin data collection.
on 2 turntable belt and DD. zoom in for details… Record quality matters a lot, but record also show other things than just speed, vibrations etc.
Belt simulator
The belt should be stored in both directions, turned over, to see which is the best orientation?
what do you mean ? it is a round belt , no onside or outside. I have 3 grooves in platter, so i can choose the best. Groove choice and time since talcum treatment affect both speed and vibrations, as do motor position and pulley size. A belt drive keeps me busy.. that is part of the fun, I use DD when I am tired of belt hazzle
can we elderly get more contrast?, it is hard to read the axis valaue and metrics.. small letters and grey-on-black, in Black mode.. is there any White mode ?
Not so much and iissue on the webpage, but when cutting and pasting snapshots they soon become hard to read if not made full page
Measuring the parameters of the Victor QL-A95 turntable using a smartphone app placed on the platter's axis.
The turntable is a Japanese import. The measurements were taken right out of the box, without any service, and as received.
Perhaps this measurement will be useful to someone.
This is fantastic and much appreciated. What is the best test record for it though? I have the Elipson one which has 3150 Hz, but the centre hole is so big I get really bad results. E.g. on my vintage Denon direct drive I get 5-8 times worse than an app. Mostly 0.55 Hz so centering, but also a seemingly large 7 Hz component, which seems strange.
If you get a slippery felt mat you can easily center your record by lightly tapping it while it's running. I watch the run-out groove with a USB microscope while doing it.
I must be doing it wrong .. when I try that I miss the correct tapping spot/ timing and cannot get it properly centered. The results are all over the place..
I end up shifting the record stationary in different clock positions/directions and trial and error.. I feel I may miss the optimal point somewhere
I have a Delrin platter which allow some movement, but maybe felt mat is better
It is a bit of a learning curve to tap it at correct place while watching the spinning inner groove. A felt mat helps since it allows quite small movements during light tapping. I usually do the process under a minute but then I know where to tap and how much.
I guess that only works with an oversize hole, or a removable centre pin I vaguely remember - was that on the Roksan Xerxes?
Use fg_analyze_vectorized.py
which file shoud we use now?," fg_analyze_vectorized.py" is gone..
what to do with what were in this github thing is not obvious to me..will there be a for dummies guideline how to implement this stuff? or are we dummies to use the webapp?
edit ,, feel even dumber now..
copied wf_core to my pythn folder and got this
No it is 85% Greek to me. I did not understand command line before 30 minutes ago. I will try more tomorrow
