- Joined
- Dec 5, 2019
- Messages
- 3,843
- Likes
- 3,790
A crap auto drip coffee maker, a terrible analogy for a CD player.
the wood dampens the harsh coffee resonances
I was going to add my own satirical diatribe about the obsolescence of vinyl, but I decided against it. For all of its benefits, too much of this forum seems to exist just to ridicule other audio enthusiasts. I decided not to add my contribution to rhetoric that I find of no benefit.
the pops and crackles on a new vinyl are due to mediocre quality control during production. Specially if they're consistent in their position.
hearing the noise floor is not THAT common, what are using as a phono-stage?
I did mine using a digital recorder, early on DAT later a Metric Halo device to a file, connected to the output of my phono stage quite some years ago.Years ago I had done some digitizing of LP's by running an interconnect from my Record out on my preamp to a Sound Blaster sound card in my computer. It worked okay but I am interested in doing some 96 KHZ sample rate at 24 bits to get some of my LP's on the music server. Equipment suggestions and / or direction to a better thread for this would be much appreciated.
In the meantime, I am going to keep the vinyl hobby for therapeutic purposes. It forces me to tolerate imperfections and be present. I cannot fall asleep or it will just go on and on.
https://www.audiosciencereview.com/...ecause-ripping-just-doesnt-sound-right.20363/Equipment suggestions and / or direction to a better thread for this would be much appreciated.
I might choose a better ADC. In fact that’s what I did—I replaced a Creative Xfi HD usb sound card with a Benchmark ADC...
While I agree that you're probably better off with a CD [or CD rip] than a needledrop, setting level for recording isn't a hassle if you're recording in 24 bit depth. LPs are lucky to have 13 bits, as regards noise. And normalizing after eq/de-clicking is better in 24 bits. When I was making needledrops regularly, the self-noise of the discs themselves was the biggest audible issue.When ever I get started ripping my Vinyl it doesn't take long for me to get frustrated with the project... tagging the tracks is the biggest hassle but there are others like setting the levels for each record, making sure the record and stylus are clean, worrying about stylus wear, wondering if the new cart / stylus / TT I am thinking about getting will be so much better that I will have to re-rip everything. For the most part I just buy the CD version of the LP and rip that unless it is too expensive or does not exist.
I've still got the Tascam DR-05 and DR-40 handheld recorders. The DR-05 is a bare bones device, DR-40 is 4 channel capable [sorta], has external microphone inputs that double as line inputs, is bigger, weighs more [which is still hardly anything]. The noise floor of both is audibly lower than the noise floor of the phono preamp connected to the cartridge. Forget about the self noise of the LP itself, that's another country. So as far as I'm concerned, they're as good at recording as I need for the purposes. I'd usually dub the discs 24/44.1 [very little to nothing going on above 10khz with worn LPs and all the LPs I dubbed were worn to a greater or lesser extent] at -10db peaks, knowing there would be peaks from clicks that would exceed that. If the disc had a reasonable noise floor, I'd use the pencil tool to draw out the rare click, otherwise use Click Repair first backwards, then forwards. I'd rarely eq LP transfers, but usually filtered 78 transfers.Thanks for the suggestions thus far. I was thinking about the ADC and realized I do have a handheld Sony that will capture at 96 by 24 someplace if I can locate. I do remember taking the batteries out to prevent the leaking battery problem so it should be intact. I originally had purchased it to record my Son's college orchestra concerts but never got around to trying the line input. It was somewhat pricey 12 years ago as I recall - maybe a $500 item - which might make it equal to cheaper options today.
The way I used to rip the LP's with the Sound Blaster Platinum - old I know - was an album side at a time. Just like playing a record and I am fine with that as it appeals to productive laziness. A lot of folks have mentioned not being worried about the quality of the rip because of the limited dynamic range or inherent noise floor of vinyl. Two things come to mind immediately. First, if you already have noise the last thing you want to do is add something to that. Secondly, the higher sample rate and greater bit depth minimize digital filter effects. Storage space is a non issue nowadays so no real reason to skimp on sampling. I must really take care of my vinyl because seldom am I bothered by pops and clicks. Cleaning at least once with a good record cleaning machine can work wonders. If you do have a damaged area - it will create a spike that can overload phono stages. The better phono stages deal with this with more headroom and appropriate amount of feedback to have a graceful recovery.
Would it be easier and cheaper to find something to buy on CD or download? Possibly. The reason for me to consider is the fun involved. As long as I stay out of the "more fun than a person should be allowed to have" category, all will be good.
Convenience is a subjective I thing. I have a DIY system that I can control multiple ways.... from a PC a phone or fully old school with a pre-amp and no screens when playing vinyl. Depending on my mood I often times find that it is more convenient to use my system in old school vinyl mode. All I do is turn it on, put a LP on the deck, and play music with knobs to control volume and tone... no screens, sliders, mice, flashing apps, searching for music and mis-typing etc. Other times I can appreciate the advantages of a screen based streaming and indexed storage system and long playing times without intervention.Two years ago I bought a new Project TT and a bunch of new vinyl. After going through all the nostalgic bullsh**t of setting it up and screwing around with the tonearm, cartridge, etc. I finally started spinning vinyl. I did this for a few weeks and the sound quality was actually surprisingly good.
But I grew weary of all the work required and now my TT is collecting dust in an upstairs closet. Whether I like it or not convenience trumps vinyl.
I would also categorize "being able to find new music anywhere" under convenience factors. Since getting my turntable working, I've been listening to a lot of records I bought in second hand shops of different kinds during the past few years. Some of this stuff might be difficult to stumble upon as digital files, and I doubt there would be sonic improvements either. By new I mean "new to me" since some of this stuff is.....quite old, for example
