Count Arthur
- Joined
- Jan 10, 2020
- Messages
- 3,162
- Likes
- 8,299
Thank you so a interface is definitely needed..
Possibly not. If I uninstalled the Madiface driver and messed around, maybe used the VB-Audio software that Keith suggested above, I might be able to get it to work.
However, I don't really want to do that and possibly screw something up. If you don't have RME Madiface installed, and use WASAPI, chances are you won't run into the problem I did.
Given that Thomann sell the version of ARC with the microphone for very little more than the version without, I'd be inclined to get it with the microphone. If you are unable to get the UMIK-1 to work, you could then get an audio interface. Swissonic, Thomann's own brand, make some fairly inexpensive models which are likely perfectly adequate for taking measurements or you could try Ebay for something used:
Swissonic Audio 1
2x2 USB 2.0 Audio Interface Resolution: 192 kHz / 24 Bit, Inputs: 1x XLR and 1x 6.3 mm jack, Microphone preamplifier with 48 V phantom powering, Hi-Z instrument input, Output: 2x 6.3 mm mono jack output, Various direct monitoring options: Off....
