The ultimate guide to Bluetooth headphones: LDAC isn’t Hi-res
Sythrix
Grave
Pretending that HRA matters.
Not reaching CD quality would be the real problem.
BillG
Auckland, New Zealand
Anyone that truly cares will go into developer options on their device and use the highest bandwidth setting. Everyone else will be still get a good enough audio quality experience not to care that much.
Bluetooth codecs focus on battery conservation as a first priority, since the protocol is typically used for mobile devices, and audio quality second.
Still after high res, wireless audio? Use WiFi... :cool:
Sythrix
Sythrix
Yeah, except the packet loss at those settings becomes ridiculous unless you have exceptional signal quality, which isn't going to happen while running, working out, etc.
That's why they made this article. It's basically worse than SBC at 330 kbs, where it's stable, and higher rates are unobtainable without perfect conditions.
