The Topping E8x8 Pre in practice. A few thoughts and first impressions.
thanks for all the info @yo! ; can I ask, can you set up a routing / software mix in the software, save to the device, and then use it without usb connected but only the mains?
I did a quick test.
Activated the mic 48V, set it unmute and routet it to the heaphone out 1.
Saved all to the device.
Unplugged USB.
At least with this scenario, I get sound on the headphone out as with a stand alone unit. So, yes it works this way.
I guess it works with the main outs too, but can't get that deep into testing as the setup is sophisticated, built in the rack and I won't create more work as needed. It's hot here 33°C. :)
Awesome, thanks for following up so fast. Seems ok then. I guess this is also what you’d expect given that it has adat out so seems to be intended as dual use, either interface or 8 pre-amps. It’s nowhere documented though and audiophonics who sell the interface said “Unfortunately a computer will be always needed to be able to use settings.” but maybe my question didn’t come across as intended
Thanks again and good luck with the heat, it’s hot here as well
Reactions: yo!
