The Tale of Two Variants (Kent & Wuhan - Chord / Aune)
FeddyLost
I’ll admit that I was somewhat amazed, no I was smitten, so much so that I emailed Chord to ask if the presence/attack was dialled up to give this result? kindly Rob Watts took the time to reply with the following explanation:
By the way, it might be the reason for such difference.
I know no metric describing spatial imaging of DAC, but different transient rendering definitely might be more than enough for different presentation.
Also, it would be interesting if you remember - maybe some genres/tracks on Chord did not force you to turn volume lower?
If your experience and Watts' answer are correct, I'd hypothesize that tracks, mixed (= created from multitrack records with all processing) with delta-sigma converters in monitoring chain might sound more "correct" through Aune and somewhat more "penetrating" on Chord.
Your description resembles difference between DS and R2R dacs. So, maybe that's the point.
And it just can't be seen on standard tests with quasi stationary signals or single impulse.
Headchef
Headchef
In a jar, by the door
now that is intriguing, I’ll dig out my listening notes and compare with the wife’s “what’s he doing now” notes and see if I can identify which the tracks were, shouldn’t be too tricky.
Jimbob54
Does the Aune have configurable filters and do we know what it was set to for testing?
Germany
5E92F4D8-A442-47EC-B2B3-9BEAF766476D.jpeg.e0e079654542b4e99ca3a75018d09817.jpeg.38731625b796e...jpeg
sq225917
I see a subjectivist taking steps to eliminate sighted bias, and introducing significant rigour to his evaluation, you boys want to BTFO.
