Multiple threads here deal with DSD, but I'm yet to see a bit more depth concentrated in one place. DSD For Beginners is boring and tells very little.
Based on listening to the sound quality of DSD native from Cirrus Logic chips like that in Sonata HD Pro I find:
• S/N ratio of DSD at high volume is bad. At high volumes, you can hear noise. Not good at all!
• There is no S/N problem with PCM volume, so it is not a problem with the DAC or analog circuit.
• DSD64/2.8Mhz has a 'dry' sound in the high range, probably because of residual noise. DSD128/5.6Mhz sound is beautiful.
• PCM and DSD have different tonality? It is said that DSD has a feeling of air, but it seems better to say that it uses airy sound as a decoration.
• There is no great difference between DSD and PCM in terms of sound quality such as attenuation length, depth of space, depth, and fineness of depiction.
So none of the results were as expected. Especially when the digital volume is reduced with DSD native, it becomes more apparent, but I think one of the sound quality characteristics of DSD is the effect of residual noise. But I understand that there are many people who like this sound. Especially in Japan, the direction of the sound that has been often heard in domestic audio has long been heard, and many music production engineers are willing to make such sounds. For female vocals, it's better to make audio sound like this. Perhaps?
On the frequency axis, DSD just looks like a disadvantage. DSD has a bad S/N and is disadvantageous compared to PCM.
But there is a DSD advantage. There is a square wave comparison of DSD and PCM in the link
http://www.computeraudiophile.com/f...irect-stream-digital-18636-print/index11.html, but the DSD square wave response here shows a very quick response closer to NOS. The biggest advantage of DSD seems to be the fast time base response. This will not happen depending on the data converted from PCM, the intermediate processing, and the way of filtering, and it seems that the response is not much different from PCM like the image at the link destination above.
DXD is 24bit 352.8kHz. It's a lot like DSD.
Some reasons for the difference in sound between DSD and PCM:
I haven't made a strict comparison, so I can't make a hypothesis.
• Influence of high frequency noise due to noise shaping included in the DSD method itself
• Difference between DSD and PCM due to characteristics of digital filter applied inside DAC
• For DSD native data, the response on the time axis is as fast as NOS
• DSD affects the current/ power consumption and power supply noise due to the amount of computation inside the DAC. Higher sound quality = lighter processing with DSD the calculation load inside the DAC is lighter.
• The effect of deterioration due to jitter does not exist in DSD. Jitter countermeasures aren't necessary for DSD.
I think DSD's greatest advantage is the third point. In the case of properly filtered DSD data that does not go through PCM at all, the time axis response of the area that could not be reproduced by DXD is possible. When converting this to PCM, it is likely that the superiority of the time axis will be lost unless it is considerably high sampling data (ideal is 384 k or more?). Of course, when the data of the CD sound source is originally DSD, the information on the time axis has already been lost, so this advantage does not occur. The high-frequency noise of DSD is only added while the time base information is lost. Pure DSD is the only way.
Therefore, if you're not a time domain sensitive listener, you should not be so concerned about choosing between PCM or DSD. Converting files to DSD just to take advantage of the 'better sound' from the DAC or software is also conceivable. Convert all the sources you have into DSD? I can't recommend it. DSD does not increase the information on the time axis of PCM files.
Depending on the type of DAC, even if DSD is input, it may be converted to PCM internally, so in that case there is no point in sticking to DSD at all.
But
http://www.computeraudiophile.com/f...ream-digital-volume-control-19955/index3.html
In short, it seems that it is converting DSD to DSD rated PCM and doing volume processing etc. Since the rate is not reduced by decimation and the original amount of information is maintained, this will not cause any deterioration in the data. It's converted to an ESS proprietary format that is neither PCM nor DSD. ESS may have less S/N deterioration from DSD volume control than Cirrus, perhaps due to better internal processing in the latter stages. Anyway, that doesn't serve as a reason to favor E1DA over Sonata Pro.
