The sound quality of DSD?
It may be that they erroneously credited the mastering engineer for the vinyl version.
Maybe. I can't find anything to confirm or deny that those CDs have no mastering. I actually found nothing on-line about their provenance except 'They used the original master tapes where they were available.' But the terms 'master tape' and 'original' aren't really definitive of anything in isolation.
Original mastertape means that they used the original mastering (probally for vinyl records) and put that on the cd. That is done often and that gives good results if the original mastering was well done. CD has a bigger bandwidth (in dynamics and frequency response) than vinyl so the audio will fit the medium. It will sound much like the original pressing on vinyl, but cleaner.
Yes, they use the mixdown tape which is called the "original master." Nothing else is. A mastered tape would have compression on it. The old MoFi CDs are full dynamic range. Just cutting out another processor makes it sound better.
A mastered tape is probably called a "production master" or something of that ilk.
Yes, but companies offering us remasters 'from the master tapes' don't always exactly specify which generation of master tape they are using -- even when they say 'original master tapes'.
And there exist albums where elements or fades that were approved for final release don't actually exist on the original mixdown master -- they were 'flown in' during final media production and may *only* exist on a 'production master'. Otherwise they have to be re-created.
Also, there are albums where something was just plain off during mixdown to the final stereo master. EQ , tape speed, crappy monitors..... These may be 'corrected' in later releases.
No, it isn't *meant* to imply that. Though it may mean that in practice.
The first gen of CDs -- some number of which were sourced from vinyl production master tapes of unknown generation -- didn't tout themselves as being from 'original master tapes'. People in the early razzle dazzle days of CD just assumed that record companies would use the best tape source they could find...instead, the companies used the tape source closest to hand.
I believe you're mistaken. A mastered tape would always have compression on it.
A stereo mixdown master could and would have compression on it too. In the pop music field, analog compression was widespread well before the digital era. Applied both to individual instrumental/vocal tracks, and to the mix.
