I have decided to replace my current passive rear speakers in my new living room with an active 2-way design
The design idea is to merge two spheres into a single cabinet using the SB SATORI AT60NC-4 tweeters with a custom waveguide and the SB17NRX2C35-4 6" woofers.
This is how the 3D design looks like:
And this is how the final product was built:
I love this snowman design, hence the name of the project
Now the on/off-axis measurements from 50cm of both the tweeter (with the custom waveguide) and the woofer:
I plan to cross them at around 2500Hz with 48dB/oct, linear phase, using my own Pataki Audio Janus plugin.
The response alignment could be better but I think it is OK
I will later perform some more exhaustive measurements from the listening position
Stay tuned!
Stay tuned!
