How big are they and how much power do they draw? When ever i see the number 15 i get scared.
Large speakers and drivers are not intrinsically harder to drive than small speakers. Actually the opposite.
Larger drivers need less power than smaller drivers to get the same output, all other things being equal.
Here are three similar drivers, all loaded into sealed cabinets with the with Q(TC) = 0.8:
If you want the sub that is easiest on your electrical system, the 15" is 2dB more efficient above 80 Hz than the 12" and 3dB more efficient than the 10". The 15" has about twice the cone area as the 10" and has similar electrical characteristics, so it's no surprise that it is twice as easy to drive (half the power).
Below 80 Hz the smaller woofers roll off earlier, so if you were to EQ these to the same response the differences in power requirements would be even more dramatic, making the larger woofer even easier to get the same response.
Also, larger membrane area means the woofer isn't working as hard with the same signal, lowering distortion which is directly related to excursion.
Comment on opposed subs. Opposed subs help with self-vibration. A dual-opposed 10" will have roughly the same output as a single 15" (same membrane area). I find placing multiple subs to deal with room modes way more important than the force-cancelation of dual-opposed. Don't get me wrong, I have been building opposed passive radiator subs for ages since the drone cones can get a sub vibrating unless opposed drones are used (the drones typically use lots of added mass in a PR system). It's just not the biggest deal especially with subs which have effective mass much lower than drones.
I modeled sealed subs above. Ported systems will scale the same way with larger woofers, with the added benefit of being even easier to drive than sealed to a given SPL due to the increased efficiency of the port's output.
