Sokel
- Joined
- Sep 8, 2021
- Messages
- 10,627
- Likes
- 11,526
The only commercial set-up I have experienced in a big space (more than 200m²) that is pure fun consists of 2-meter high horns.In order to reach these levels without high distortion and compression, plus have a speaker that measures well off-axis and on-axis I'm not sure there's anything else than a large horn speaker and preferably with a separate subwoofer/bass solution. As I've said ealier though, I'm biased here.
I honestly don't know what I would have purchased myself if I was going to buy a horn speaker off-shelf. I don't see any that tick all the important features to me. Perhaps the Klipsch Jubilee or Danley Hyperion would have been the closest but I'm well aware of their drawbacks. I have owned the Klipsch K-402 horn (top horn on the Jubilee) and have both measured and listened to it extensively. We used it as a reference when designing our horn.
What commercial horn speaker combines active crossover with time alignment between drivers, have low diffraction, great horizontal and vertical polars, maintains directivity in both planes at least down to 500-600 Hz, doesn't overly beam (become very narrow as frequency goes up), use high quality drivers (like beryllium compression driver), avoid the floor bounce, and have horn loaded midbass for higher SPL and lower distortion? To my knowledge it doesn't exist and it's one of the reasons why many horn enthusiasts go with DIY.
You could of course reach those levels with a traditional line array as well. However, in a traditional line array the drivers don't sum well, leading to interference between drivers and what I would describe as non coherent sound (at least to my ears). A CBT speaker resolves this with shading and curving, but wouldn't reach the levels in the highs unless you go custom. That being said, we don't need as much SPL in the high since music material have much less level here. With a traditional CBT speaker, the horizontal dispersion is very wide (180°) which is similar to Revel and most speaker designs.
They are not lookers but is pure joy,thunderous,delicate,etc.
There are no measurements around but I believe they are typical of the kind.
All the other big space set-ups I know are installed by pros.
