I set out to produce a set of proof of concept measurements with the methodology i suggested before. My hypothesis was that you would see a meaningfully higher SPL from the microphone when placed on the side closest to the speaker while playing a tone from a typical left speaker angle. When repeating the measurements from dead center, the difference between left and right microphone placements would disappear.
I played a 3000Hz tone through the left speaker, and measured the SPL on the left and right side of a dummy head (a rubber ball). I repeated this measurement two times, alternating sides for each pass, and compared the recorded SPLs from 5s-10s so the measurement was settled in. I then did the same thing with a speaker centered with the ball. These were not expected to get highly repeatable measurements because the microphone was simply placed by hand on a cushion, and I wanted to see results before fussing around with a test rig.
As you can see in the results, left ear is distinctly louder than right ear on the 60 degree measurements. When placed at 90 degrees, the measurements are closely bunched. I consider this validation of the hypothesis that the amplitude contribution to localization could be easily measured.
To improve the design, this would be much better if performed with simultaneous dual channel measurements. As well, a consistent test rig would be needed for the repeatability necessary to compare results from one pass to the next. Lastly, a more realistic dummy head would make for a better representation of the head transfer function of the measurements. Like suggested earlier, something the
miniDSP EARS should be able to perform this adequately if it can be used in a dual channel mode.
Finally, I would be very interested to perform a similar test with phase comparison - alas, this will definitely require dual channel measurement. I'll think about whether or not I'm motivated to go out and get the equipment necessary to take this further.
