No_hair_left
- Joined
- Nov 2, 2023
- Messages
- 116
- Likes
- 20
I tried this and it just won't work for me, tried resetting the avr but it still is boosting the rears even when set to off, must be a bug.
I my current version on the AV10 has an option to control this and set the amount correct done to surround channels, even to noneOverall I'm quite happy with what DEQ does to the frequency response (boosting bass and the high end); but I don't like what it does to the surround channel levels. I just made some measurements with different Dynamic EQ settings to confirm my impression that it boosts the surround channels too much.
(Please ignore the generally lumpy response - this isn't about that and I realised that my minidsp sub settings were messed up part way through).
For the centre and front channels the level of the mid frequencies remains fairly constant with different DEQ settings.
But for the surround channels it also boosts the overall level...
The situation is even worse when listening at lower levels...
In the kHz range I think the level should stay roughly where the black line (DEQ off) is. With the DEQ set at 0dB offset it boosts the surrounds by at least 6dB, relative to the fronts.
I assume this is how it is intended to operate (and not an implementation error in my Denon AVC-X receiver). But for me, since I sit a lot closer to the surrounds than the front speakers the boosted surrounds are pretty obnoxious.
For quiet listening in the evening the surrounds are close to me and louder. If I set volume based on the surrounds the centre channel is too quiet - reducing dialogue intelligibility (a common problem). Alternatively if I set volume based on the centre channel I get blasted by loud music and effects from the surrounds, eg when the adverts come on.
Edit: Added poll
I didn't know there was a surround level compensation setting...but yes surrounds get boosted. I just adjust to taste in Levels.Does anyone have Dynamic EQ on with Surround Level cCmpensation set to off and still feel like surrounds are boosted a tiny bit (like a couple dB)? I have a Cinema 50, and it seems like I have to tone down the surrounds on my 5.2.4 set-up by ~2 dB to level match them with the fronts. I saw a post on Reddit saying roughly the same thing before I think the OP deleted it. ~2 dB is way better than the 8.5 dB that the Heavy/default was set to, but I assumed off would be off.
Is anyone else experiencing this?
Yeah, it's only for some receivers, but the firmware update that added Surround Level Compensation was added just in the last couple weeks. There was some discussion here over the past couple pages.I didn't know there was a surround level compensation setting...but yes surrounds get boosted. I just adjust to taste in Levels.
I see. Well, I have the X8500H and I think they are done with firmware updates for that model...so it seems..Yeah, it's only for some receivers, but the firmware update that added Surround Level Compensation was added just in the last couple weeks. There was some discussion here over the past couple pages.
That's really cool. Are there any plans to roll this update out for slightly older models (I'm rocking a Denon AVR-X6700H)? Or am I outta luck?This is great addition indeed. I sent message to Audyssey directly requiring this few months ago. Never got reply back from them, but now it`s added.
If the volume setting on the unit is below the reference level when using Audyssey Dynamic EQ, the volume of the channels located behind the listener is amplified in accordance with that volume setting to maintain the surround experience for the listener.
Surround Level Compensation can adjust the amplification level.
Heavy
(Default):
Surround and rear channels are increased in level up to 8.5dB based on the master volume, when Dynamic EQ is on.
Medium:
Surround and rear channels are increased in level up to 5.6dB based on the master volume, when Dynamic EQ is on.
Light:
Surround and rear channels are increased in level up to 2.8dB based on the master volume, when Dynamic EQ is on.
Off:
Surround and rear channels are not increased when Dynamic EQ is on.
A few years back, when I was still in the Audyssey camp, I used to use DEQ quite frequently for exactly what it is designed for - watching movies late at night... at lower volume levels due to others sleeping in the house...These are all excellent questions. I would like to know the answers, if for nothing else academic reasons. I was never really patient enough to figure out DEQ and what it really does. And really never felt like this was a solution I really needed on top of my bass management.
Yes, you can.From what I've read, Dynamic EQ boosts the surrounds by 1 dB per every 5 dB below reference you set your master volume. So if I usually listen to movies at -30 dBFS, my surrounds are boosted by 6 dB. Given the new Surround Level Compensation setting wasn't added to my Denon AVR-X6700H, can I simply use the Channel Level Adjust of a given input of my receiver to lower the surrounds by 6 dB to counteract the DEQ boost?
If your question is regarding the surround boost, then it shouldn't affect front wides--but your testing can easily confirm it. Measure and let us know.Also, does DEQ also affect the Front Wides, or only the surrounds?
