Yes, the delay from the side wall reflection of about 20 to 25ms increases envelopment of the sound without much negative effect.
You also need the direction of the reflected sound. The delay on its own isn't enough, as far as I know.
It is interesting if this actually works this way since the reflection has its origin form the other speaker and is therefore mirrored?
To get an estimate of the room size I calculated the room width. I assume a standard stereo triangle (equal triangle, listening distance = width between L and R speaker).
| Listening distance [m] | Room width (20ms delay) [m] | Room width (22.5ms delay) [m] | Room width (25ms delay) [m] |
| 1 | 8.14 | 9.00 | 9.87 |
| 2 | 9.35 | 10.22 | 11.09 |
| 3 | 10.53 | 11.40 | 12.38 |
| 4 | 11.68 | 12.57 | 13.45 |
You can see that the room has to be bigger for this.
If you want to calculate it by yourself you can solve the following formula:
w=2*b+a
b=-a/(2*2^0.5)+(a^2/8+0.5*c*d*a+0.25*c^2*d^2)^0.5
Where w is the room width [m], b is the distance from the speaker to the nearest side wall [m], a is the listening distance aka length of the stereo triangle [m], c the speed of sound [m/s] and d the delay (s).
Since the best angle to create envelopment is about 60° and you can't get 25ms of delay with a standard side wall, you have to apply a trick by placing absorbers or diffusors at the side wall and use a "acoustic mirror" or a blank wall at about 60° from the listening position to get the desired 60° angle reflection.
You also can mimic these reflection with additional speaker with attenuation and delay. But you have to be caution since these speakers create new early reflections.
