Hi, I hadn't forgotten your post & your interest in K702 Oratory EQ. I did indeed contact Oratory recently re me sending in my K702 for testing and he was receptive at first, but I mentioned that my earpads were old & misshapen and after showing him pics of them I didn't hear back from him, lol - I don't think he liked what he saw! Well, yeah, if the pads are misshapen they're molded to the shape of my head now and might not fit his mannequin well, plus there is a strong argument that you would want to measure the pads as close as possible to new to get the most relevant result (afterall my pads are 5yrs old and I wore them everyday for hours).
However, I did some research recently and Jaakkpasanen has updated his AutoEQ project with target curves calibrated to the Harman Curve from "all" measurement sources (eg Innerfidelity, RTings, etc) - which means he's compared headphone measurements between Oratory (the Harman standard if you will) with say Innerfidelity's measurements of the same headphones and looked for where the differences lie....and thereby has managed to create a calibrated Target Curve for Innerfidelity (& others like RTings) that should be pretty close the same result you'd get if Oratory had measured the headphone and applied it to the Harman Curve. I had heard of this project before, but it seems only in the last 6 months or so that he's calibrated the target curves in the manner I've described, thereby making any EQ from the measurements more accurate. So I've EQ'd my K702 using this philosophy, I've taken the Innerfidelity measurements of the K702 and applied them to the calibrated Innerfidelity Harman Curve using my own EQ - in my listening I do think it is the most accurate EQ yet, and is pleasurable to listen to.....when I say it's accurate I mean that it sounds very similar to my 2 other properly Harman EQ'd headphones (NAD HP50 & Sennheiser HD600 from Oratory measurements) as well as sounding similar to my Harman Curve Room EQ'd JBL 308p Mkii Speakers. Feel free to try out my Harman Curve EQ for the K702, you'll need to apply a
negative preamp of -4.8dB to go with these filters, managed to get it pretty much spot on to the target curve whilst using low Q filters (not sharp filters):
K702 Harman Curve EQ (using the calibrated to Oratory Innerfidelity Harman Curve):
And here's the website where I got the measurements from if you've not heard of Jaakkopasanen:
https://github.com/jaakkopasanen/AutoEq
