totti1965
The new king of passive speakers - according to spinorama.org ranking - KEF Blade 2 Meta: preference Score without EQ 7.07 and with EQ 7.68
Two months ago, Erin from Erin`s Audio Corner was very impressed by the KEF Blade 2 Meta.
The spinorama data were exceptionell - with an extremely good score also without EQ.
But on spinorama.org there was a bug in the Graphs of the estimated in-room response.
The frequency seemed not lower down at higher frequencies. So I contacted Pierre Aubert from spinorama.org.
Pierre was so nice and corrected the bug!
You can see the corrected data in the developer site of spinorama.org:
dev.spinorama.org
or at github with TWO DIFFERENT EQ Suggestions:
github.com
Perhaps these new graphs are on the normal spinorama.org site from tomorrow on also.
There will be also 8 new speakers - including the Nubert NuVero 60 from germany which gets 6.88 points after equalisation.
Very good, but no one-in-a-century sensation.
And the beautifull XMechanik Mechano23 DIY with a score of 6.81 points after equalisation.
thorsten
Measurements for speaker KEF Blade 2 Meta
KEF Blade 2 Meta - Bug in In-Room-Frequency response "with EQ" · Issue #269 · pierreaubert/spinorama
*Bonjour Pierre, Il doit y avoir un problème avec les données d'Erins pour le Kef Blade 2 Meta ! Jetez un coup d'oeil aux données corrigées ! La correction rend la réponse en fréquence bien pire qu...
thorsten
