Because white noise and or frequency sweeps could also be described as "music consisting of every frequency at equal tempo and average level"?And why not?
this changes everythingi mean its not like music is actually just a bunch of sine waves or anything...
You have to answer my question first ....
See other replies regarding your question 'why not?'
If one is talking about music and you answer and argue/measure with tones, why should I answer this? It is not consistent. That's it. Music vs tones is widely discussed with no consensus ever. So I dont really understand why we should stick to here.
Might be, could be, but is it the same, measuring music than measuring tones? I dont know ......any waveform that you see in any music track can actually be broken down into individual sine waves, said waveform is really just a result of all these individual sine waves being summed into a single waveform...
Again, if one is talking about music, why dont you measure and come up with that instead of measuring tones?Music vs tones has a clear relation when tested blind and under controled conditions.
Music vs tones has a little relation when tested sighted for sure.
I also agree that there isn't full correlation when looking for borders of audibility between test tones and music.
And agree that 1dB lift in the lows is audible... but is just 1dB for the HD800.
In this case the boost in the lows is purely due to voltage division, this is exactly the same for music and tones.
Yes @digicidal, but besides that, how can one come up with tones when the discussion is about perceiving music ..... and still insist that this is consistent?
not sure what you're getting at but im trying to say that there isn't anything "magical" about music that makes it "special", that sets it apart from a bunch of sine waves... that comment is made in jest and poking fun at the idea that music has a magical property that makes it different from artificially generated sine waves
No one discussing this, at no time. But again, does one or two tones measure the same way like music? Do you have any even remote evidence for that? Senseless.Noise is LOTS of tones, even more so than in music and the handy part (with white noise) is that averaged over time the amplitude is the same for all frequencies that are present simultaniously.
Again, yes, by lots of them, not just one test tone. Measuring one test tone is the same like measuring thousands of them at once? I doubt it. So, that's my very last comment on this topic. Unwatched this thread..You do know that music can be represented by visual waveforms, right? You can record music from the same source and it'll always look the same. Are you suggesting otherwise?
