The kit we bought, our current setups
scrubb
Chicago, IL
Sources:
Bluesound Node 2i —> SMSL M500
Pro-ject Debut Carbon w/ acrylic platter—> Jolida JD-9 preamp
Panasonic DP-UB9000
Roku
Processing:
NAD T758 V3
Amps:
NAD T758 V3 for Center and Surround.
Adcom GFA-555 for L & R
Speakers:
Goldenear Triton 3+
Elac Debut Center
(2) JBL Control 1 as surrounds
The NAD is the king of Amir’s “broken” category but I’m really like Dirac live and typically run “analog bypass” mode when listening to music. Also, the 200 watt Adcom really kicks it up a notch.
mlee
Hi All,
This site has influenced my purchases as of late!!!! 2 CH is great but I also like multichannel for movies. Sorry for the bad pics.
Mains:
3-way open baffle line arrays.
Custom minisharc(MS) DSP. Outputs of MS is toslink to 3 times soncuz la-qxd1 balanced to Buckeye 6 Channel NC252MP.
Denon AVRX-3600H for the rest.
Thanks ASR!!!
D
Deleted member 24907
Guest
A Princess toaster creating voices
, Tannoy XT8F, supra py 3.4s speaker cable, NAD C368, coax->node 2i. Cheap LG bluray player as cd player using spdif. Old Samsung Plasma still going strong. NAD C298 coming next. Previous speakers were Teufel Ultima 40 MKII. Before that a Pioneer VSX 2014i receiver with B&W 600 serie 3.
pads
Picked up a GoldNote Ph 10 mainly so I can run my two tables, one with an MM cart the other an MC. It's been a little bit of a learning curve as the instructions are somewhat lacking but so far it's excellent with the gain and impedance easily set with one rotating knob which beats fiddling with dip switches. The little Moon phono was great but only took one table at a time so switching out was a chore and totalling harshing my DJ vibe....:)
rdenney
I said in my previous post that in a fit of boredom, I had purchased both an Arcam CD93 and a Cambridge Audio CXC. I was away for the month of January to handle a family emergency in another state, and wasn't here when the Arcam finally arrived about four weeks after I bought it. I tested it and it must go back--there is a very loud (maybe -20 dBFS) hiss in the audio output and something is obviously amiss in the audio section. The digital output worked fine, but that's not the itch I was scratching with that purchase, so back it goes. But the itch still needed scratching, so I have purchased another CD player of vaunted sound qualities from about that era (early 2000's)--a Naim CD5. It should arrive next week.
No, I do not expect the Naim to sound particularly different than my current player, a Tascam CD-401, which I already can't distinguish from the Cambridge CXC feeding a Musical Fidelity DAC. But it uses a Philips transport that is more robust than the Sanyo transport in the Cambridge, and (a bit) more serviceable than the otherwise lovely Sony KSS151 in the older Tascam. And Naim reportedly kept a stock of parts, though I bet that doesn't last forever. But it lacks the usual fragile drawer--no plastic gears to crack and no belts to turn to goo. The drawerless Philips transport usually means a top-loader, but Naim mounted it to a rotating tray that rolls laterally out the front using human power, bringing the whole transport with it, and clamps the CD using a manually placed magnetic puck. Drawers have been the weak links in my CD player history, but a top-loader doesn't work in my setup.
(pic from Stereophile review.)
No, I'm not going to buy the "upgrade" power supply. Nor am I going to buy a Naim interconnect--I found an inexpensive but still well-shielded DIN to RCA adaptor on Amazon, and I'll make the link plug that allows the use of the internal power supply. The seller wrote in the listing that it can only be used with a Naim preamp and power supply. Uh, yeah.
If I am astounded by this or that when it arrives, I will seek to find out why in measurable terms. I suspect the CXC will be the more transparent, feeding into a Topping E30 as it will be once I unbox and install the latter. Even though I don't expect one to be better or worse than the other (or even different), I'm sort-of hoping that it is just to have something to talk about.
I really don't mind having two CD players in one system.
(The seller, in the discussion about the Arcam's fault and needed return, didn't take my word for it completely when I told him I tested it several times, alternating between the Arcam and my Tascam, using the same interconnects moved back and forth. He asked me to bypass the preamp and plug it straight into my amp, because preamps are "only needed for phonos". My amps, of course, have no volume controls. I told him conducting that test would ruin my speakers, my ears, possibly my amps, and certainly my domestic harmony, and not necessarily in that order. He relented.)
Rick "thinking the Philips transports were the more reliably built of those that were available in the early 2000's" Denney
Colonel7
Maryland, USA
Near-field covid set-up of C-notes and an amp board in a repurposed box. Surprise, I think my wife is planning on taking it over when things get normal-ish because she likes the sound and is a remote worker.
dfuller
Current rig is in my sig. WAV CD rips or Spotify (gasp!) to my ADI-2 Pro FS, which goes out via XLR to my Barefoot Footprint 01s in nearfield. Headphones, at home it's Sennheiser HD6XXs, on the go it's IE40 Pros. I have a pair of ATH-M50s, but I never use them. Mic preamps are ART TransX, which are honestly way better than they have any business being for $500 for 2 preamps. Clean they are not, but the character they have is pleasing on every source I've tried them on.
Past stuff I've had:
Speakers:
- Equator Audio D5 (rather dark, but stereo imaging was immaculate and the sweet spot was as wide as could be)
- Dayton BR-1 kit (still have these, they're in my living room, not bad for what they are and very easy to build)
- Focal Alpha 65 (solid if unremarkable; I like these better than the HS8s they compete with)
- Adam S3A (Words cannot describe how much I viscerally hated these. Nothing translated right off them. Also, the quoted F3 of 25Hz is total BS - no way did they get that low)
- Focal Shape 65 (Overall good, but F3 of 40hz seems like a total lie considering the F3 of my FP01s is 36 hz and they seem to end up much, much lower)
Audio interfaces/DACs
- Lexicon Alpha (this was such a long time ago, I don't remember anything about it other than its ASIO driver barely worked)
- Focusrite Saffire 6 USB (This was such a step up from the Lexicon just because it actually worked properly...)
- Focusrite Saffire Pro 40 (Surprisingly, this was much better than the Saffire 6. I think the mains powered Focusrite prosumer stuff runs at higher internal voltages than bus powered, because it was way less prone to clipping on the inputs.)
- Universal Audio Apollo Twin Duo (1st gen silverface, Thunderbolt) (now this? This was a big step up. Shame about its total incompatibility with Windows at the time, which is why I ended up selling it)
- Audient iD22 (other than the kind of janky driver situation, this was pretty solid - I liked the integrated monitor controller features a lot and the actual straight-to-converter line inputs were always appreciated. Preamps were pretty good too...)
- Schiit Modius (I bought this as a temporary piece while I was waiting for my ADI-2 to show up. Sounded fine, but the total lack of volume control was annoying as hell.)
Amps:
- Crown XLS1000 (When I was using the BR-1s as monitors, this was my amp. I sold it to a bassist who needed a power amp for his rack rig... he plays in Intervals, if any of you are curious).
Septentrio
Portugal
In my study:
1. Desktop PC;
2. Topping DX7 Pro;
3. Neumann KH80 monitors.
Not enought room for a sub.
The room where I work out at (cyling - Zwift):
1. Laptop;
2. Topping D70;
3. Genelec 8010.
Living room (no speakers, I only listen with headphones at night, when I'm reading):
1. TV/NVIDIA Shield;
2. Topping DX3 Pro;
3. Sennheiser HD600.
I also own a Synology NAS.
Back at the office:
1. Laptop;
2. Topping DX3 Pro;
3. Adam A5X;
4. Sennheiser HD599.
Good enough for me :D
rdenney
Someone brought up their recording stuff, so I’ll mention mine.
Audio-Technica AT-822 stereo microphone > Presonus Studio 24C USB interface > laptop.
The Presonus has quite decent microphone preamps with a little more gain and much more portability than my Benchmark ADC, and the loopback test I did with REW showed it to be more than sufficiently transparent. It also will mix microphones and computer-based backing tracks into headphones with good adjustability. The headphones are Koss Pro4S, but I did order an AKG K371 this week, based on Amir’s review.
I use the Presonus for REW room measurements, too. It has line-level “main” outputs that I can feed into a currently unused input on my Adcom preamp.
Rick “uses it for recording tuba parts” Denney
danzilla31
20201011_165303.jpg20200912_190114.jpg20200912_190210.jpg20191210_111607.jpg20200307_172713.jpg20200307_172722.jpg
New member long time lurker
Room dimension 29 long by 18 wide by 9 ft high
Has been sound treated light controlled
2 rows 2nd on riser 2nd row is sweet spot
Equipment projector epson 6050ub
Screen Black Diamond ALR we watch a lot of sports with people in and out so I needed a screen that ciuld handle some light
Processor Anthem AVM 60
Amplifiers Anthem MCA 525 and Anthem PVA 7
Roku Ultra
Apple 4k
Sony 4k UBP X800
Speakers front 3 JBL 590's for L C R
Surrounds 4 RBH SV-661W on walls
In ceilings 4 paradigm CI Elite E80-IW
Subwoofers 1 RBH-SV1212PR
1 RBH-SV1212NR plan on adding 2 more for 4 total
Enjoy any constructive feedback is appreciated!
DonH56
Monument, CO
Updated, now with heights added. Same small room so pretty packed but what the heck...
  • 65" LG OLED (few years old, don't remember model), cable box, Sonos Connect, Oppo UDP-203
  • JBL SDP-75, Emotiva XPA-2 (L/R), Emotiva XPA-5 (C/Surrounds/Rears), Buckeye Amps 4-ch NC252 (heights)
  • Revel speakers: 6 x Salon2, Voice2, 4 x M80XC (heights); 4 x Rythmik F12 subwoofers; surrounds barely visible near couch
  • Room is 13'3" W x 17'7" L x 8'5" H; concrete floor, isolated walls/ceiling double drywall on Kinetics IsoMax clips, Rockwool 6" walls ~12" ceiling, minsplit HVAC (no ducts to the rest of the house); various absorbers on walls and ceiling, mix of 4"/6"/12" (corner traps)
Kachda
NY
View attachment 112537View attachment 112538View attachment 112539View attachment 112541View attachment 112542View attachment 112543
Roku Ultra
Apple 4k
Sony 4k UBP X800
How do i get invited to your house ?
