The kit we bought, our current setups
Updated pics!
Super clean looking set of classic Vande 2Ce's
Have you owned them since new?
Done any service on them (woofer surrounds, refinished, etc?)
They are 2Ce Sig II's that I found used, but they were in like new condition when I got them and didn't need any work. I filled the bases with sand the other day which improved the sound.
I’m posting this to shame myself into tidying up / building some proper enclosures etc etc.
current set up is
Ageing apple mac
Rpi4 & Protodac8 HAT
Volume and balance control & 2x electronic crossovers following Elliott Sound Products designs
Four Elliott Sound products amplifiers (projects 3a and 119)
Focal JMLab 120.1 speakers modified to bypass the internal passive crossovers.
I also have a ‘Tandberg’ badged Thorens deck a Sony 400 capacity CD changer with a digital out and a monster 35kg Yamaha DSP z11 that I used to discover that surround sound does nothing for me. It does help keep the room warm when it’s on though.
All the gear I’ve either picked up cheap at house clearance auctions or bodged together myself.
When I converted the Focals I did it one at a time to check the freq response with REW and ears. Hardly any difference. Subjectively I think the soundstage is sharper with the electronic crossover but this might just be self-audio-foolishness.
Next project is to get a Hifiberry Dac8x and go all digital and see what happens.
Holy tripping hazard!
I’ve changed it up again,,,,,
March Audio P701 x2 monoblocks
Eversolo A10
Philharmonic
I am liking this setup the most so far!View attachment 465285
Nice choices. I’d love to hear the Philharmonics BMRs in person. Went the other direction with R3s when it comes to directivity. Always left me wondering “what if”
If I ever have another living room or bedroom space I’ll give them a whirl.
Just made some big changes and thought I’d catalog the current state of the main system.
The turntable on the left is a rather hot-rodded Thorens TD-166 II with TP-11 arm and Audio-Technica AT440MLb cartridge. One of the RCA plugs on the Thorens audio cable is flaky, but everything else is just as it should me. I’m currently using a Music Hall Cruise. Control to power the motor, which gives me speed adjustment.
The open-reel deck on the right is a Teac 4300, which I repaired and adjusted in a thread on ASR.
The amp is at the bottom, a Buckeye NC502MP stereo amp driving (not shown) Revel F12 towers. Going into the amp is a balanced converter that uses a THAT 1646 Outsmarts chip.
Here’s the crazy stack, a study in aesthetic chaos.
The Sony XDR-FSD HD tuner has been extensively enhanced. I’m auditioning it as a replacement for the Carver TX-A11a tuner that is below the CD players. Currently, the Sony has a noise problem—the added cooling fan is audible everywhere in the room. It will probably end up in a different system.
The top rack-width component is a dbx signal router Model 400. I’m using it to expand my tape loops. The preamp has two tape loops, and I use one for the computer and the other for this unit. It provides tape loops for the cassette and open-reel tape decks.
Right below that is a Holman preamp, the testing of which is described in its own thread.
Then there are the two CD players. The top one is an old Naim Audio CD-5. I got this because it’s the only quality CD player that does not use a plastic drawer or any belts. This one is tip-top so I’m withdrawing the Cambridge Audio player that I’ve discussed before for use elsewhere. That one is too modern for this system. The Philips VAM1205 laser unit in the Naim isn’t high-end and will eventually die, but most of my CD players fail because of drawer mechanics. I use this for playing whole CDs for plain listening.
The other CD player is a Marantz PMD-331, which provides every control feature known to man. It’s the opposite of the Naim, but the drawer is already a little flaky, so I use it if I need something like an A-B loop, like for playing along on the tuba.
Below the Carver tuner is a Yamaha YDP2006 digital parametric equalizer for room-correction EQ. It connects using the preamp’s processor loop.
At the bottom on the lower cabinet shelf is a Nakamichi 480 cassette deck. I like this better in the main system than the very fiddly BX300 I also have.
Not shown are the components that connect to the computer. I’m using a Benchmark ADC-1 USB and a Musical Fidelity V90 DAC. The DAC measures “okay”, but it’s still better than the rest of the system.
For CD playback, the overall SINAD should be about 85 dB, which is very good for a vintage system.
The turntable may be replaced by a Linn Axis given to me by a friend in non-functioning state. I have to fix it first, and then decide if it’s an improvement on the Thorens. It should be, on paper at least, if for no other reason because of the Basik tonearm.
Rick “always in flux” Denney
Eeeeeek :oops:, all that stuff piled up is setting my “itch” off.
Always changing - for some reason I ended up with two Bang und Olufson TT's - but, I got the original boxes for those, so I can ship, if/when somebody eventually buys one...
Speakers are, amongst others - Edgarhorn Slimlines, two subs... they don't do anything under about 90 well, but the mid-range is fantastic.
Latest purchase, picked up today. Inkognito Gen 2, hardly a year old. Next weekend will be interesting!
Have to clean up this weekend. The Q300s are going into storage, along with the nova65se. Carina 150 arrives tomorrow, so im excited about that.
Tv mount also is needed, but got to do some homework on a decent one.
Added a Denon DCD 900NE CD Player to my setup so I can continue to play my sizeable collection of music CDs, a few which are shown in the image below. When listening to music, I have the system play in stereo powering only the front LR channels and the subwoofer. For movies, shows I have all speakers powered plus the butt kicker transducers behind my seat.
I’ve only just seen this thread and waded through the latter half. Very fun!
My wife and I have had this system for almost 10 years now, and it still brings us just as much joy now as it did when I built it.
Thiel CS 2.4 SE
Lenovo tiny PC in a case, running Linux and MusicPD
Bel Canto REF Link USB to AES adapter
Ayre C-5
Bel Canto DAC 2.5
Bel Canto REF500M x 2
Some Furman device that's a glorified power strip
We recently inherited an Ayre C-5, so that's in the system. I use a Henry Engineering 3 input 1 output AES switch to toggle between the USB converter and the CD player.
Power cables are various lengths from the endless supply available at a data center. AES and balanced cables are Mogami, bought on eBay.
I got the Bel Canto stuff for a great price back in the day. While it is certainly a bit overpriced - having the components all match is nice.
The computer case is just a 2U amp case from an Italian DIY audio company. The back panel had 6 holes machined in for D-sized connectors. I put Ethernet, USB (one for the AES adapter, one for an IR receiver), and HDMI, with two left unused.
I just had a coaxial driver repaired by Rob at Coherent Source Service. I highly recommend him for any Thiel owners out there.
The walking sticks probably need to find a new home...
My Thiel antenna immediately went up with this photo. Thiel CS 2.4 SE! Beautiful!
I own their successor, the Thiel 2.7s, last of Thiel’s T/P coherent designs with a co-ax driver. Thank goodness for Rob opening up that Thiel servicing business. That gave a lot of confidence to us Thiel owners, or even buying Thiel secondhand, that we can be taken care of. I actually bought a full complement of spare 2.7 drivers from Rob “ just in case.” Rob has retired and somebody else is running the business.
I just added decorations. Two of them, but which ones? :)
Very cool looking set up Thomas!!! Looks like serious business. And I like the decorations.
This took me a bit over 6 years (half of that was a project break), but I finally finished my dedicated soundproof home theater and listening room about a week ago. I've posted about it a few times in other threads, but not all the details. The room was almost entirely DIY from conception to completion, representing thousands of hours of my time learning, planning, and building. The theater plays flat to 10 Hz, up to 110 dB. Above 110 dB the infrasonic content compresses, but above 20 Hz or so it'll hit 115 dB.
AV Gear (7.4.4):
  • Denon AVR X4800H w/ Dirac Live Bass Control
  • Buckeye PURIFI 1ET6525SA 3-Channel Amp (for the front 3 channels)
  • Philharmonic HT Towers
  • Philharmonic HT Center
  • 4x Philharmonic True Mini as Atmos Speakers (June delivery)
  • 4x Revel S16 as Side and Rear surrounds
  • 2x Rythmik F18s in front
  • 2x JL Audio e112 Subs nearfield behind sofa
  • Sony 83" OLED TV (7' viewing distance, 46° FOV)
  • Apple TV streamer
Room:
  • Dimensions: 14' wide by 12' wide by 8' tall
  • Soundproofing:
    • Walls are 2x 5/8" drywall + 1/2" plywood and Green Glue between, 1/2" gap double stud walls decoupled with DC-04 clips
    • Ceiling is 2x 5/8" drywall and Green Glue, RSIC-1 clip/channel decoupling
    • Subfloor above ceiling has 2x 5/8" drywall and Green Glue applied between the joists
    • Walls and ceiling insulated and fully filled with Rockwool
    • HVAC supply and return have large silencers built from MDF, drywall, and GG, decoupled with DC-04 clips
    • Electrical outlets/switches have 2x thick MDF backer boxes
    • Floating Wicanders cork floor on additional hybrid cork acoustic underlayment (mostly covered by large rug)
    • Acoustic Geometry Studio 3D Soundproof Door (2 3/4" thick, >300 pounds)
  • Finish Details and Seating:
    • Walnut walls and trim made from a mix of 1/2" veneered plywood
    • Front wall and ceiling painted with Sherwin Williams Tricorn Black
    • A large Room & Board Cade leather sofa with chaise (comfortable seating for 4)
    • Custom built LED perimeter skirt lighting to illuminate the walnut walls and visually "float" the ceiling
    • 4 adjustable ceiling can lights for additional ambient lighting
  • Acoustic Treatments:
    • A total of 27 GIK acoustical panels using a mix of 7.3" monster traps and 6" Alpha panels
    • 25% coverage on all walls and ceiling
    • 8x11 Wool Rug with high pile and a 1/2" felt rug pad (1" total thickness)
My list of things remaining to complete is very small:
  • waiting on Atmos speaker delivery
  • stain/finish the maple door
  • build a walnut AV console to go under the TV (72" wide, 20" deep, 14" high)
It's a small space, so the ultra-wide angle iPhone photos distort a bit, but you get the idea. The TV feels WAY bigger in person than the pics.
Wow, did you ever do an awesome job! That room looks both comfortable, and incredibly well thought out. Congratulations it must be so satisfying. When I redid my room for both home theatre at two channel duty I struggled with the issue of acoustic treatment and aesthetics. Both because I didn’t like the look of acoustic treatment in general - reminds me too much of working in studios - but also because it was a renovation of a main floor living room and I didn’t want homely acoustic treatment all over the place.
You’ve managed to do it all, in a way that is not offputting, but looks comfortable and inviting with nice aesthetics. Congratulations.
The redesign of my listening room took me about a year and a half or two to figure out all the details. It was “DIY plus help” in the sense of the main design and choices were all mine, but I hired my architect pal and also employed a professional acoustician in an attempt to build a good sounding room, able to perform at the technical level I wanted, that also looked nice and felt inviting and cosy.
I just posted about it in the other “ show us your room thread” so here are some pictures and details:
I have to admit it feels slightly odd going through threads like this at this point, simply because after around 30 years of avid audiophiling/home theater obsessing, I’m now out of the game and not buying any new equipment. I’ll live vicariously through others :-)
My OnlyFans link to follow to help pay for it...
I wouldn't have thought of that:D
yeah, I have awesome feet! Not like nice, but because I could probably play the guitar with them... You can Venmo me for details :facepalm::D:)
