Audiolense is the first and only software product I have used that time aligns subs correctly and is repeatable, with no manual intervention. More amazing is how they possibly can be aligned when I have them crossed over so low at 40 Hz!
IMO, Bruno’s view as expressed in the LS1 manual “room correction” is typical amongst speaker designers."...much preferred the Grimm LS1S".
I wasn't aware that Grimm had a DSP software based bass management system for a full portfolio of subwoofers?
To me, this demonstrates a lack of experience with so called “room correction” software.Some companies apply DSP for ’room correction‘. We rather not use DSP in the LS1 for this since the effects are in uenced by the position of the listener. If we again look at the three acoustic factors: 1. First re ections are strongly dependent on the listeners‘ position, so there is no way to correct these with DSP. This is certainly true above 200 Hz where the wavelength is short. 2. The low frequency coupling effect can partly be compensated by DSP (please use the LS1 EQ for that). However in the region around 100 Hz where often energy is lowered due to the re ection being out of phase, DSP will not help since a louder tone will still be canceled by its re ection. 3. Finally, room modes are also strongly dependent on the position of the listener. Theoretically it should be advantageous to attenuate peaks in the room response that reside in the whole listening area, but all DSP solutions for this we tried so far challenged the LS1's performance too much.
Grimm aren’t as far as I am aware great fans of room correction, they prefer to eliminate off-axis response at source, a concept developed by the Kii THREE, Beolab 90 and Dutch&Dutch 8Cs, my experience mirrors that better to minimise at source rather than try to ‘correct’ after the fact.
I see it as just the opposite: anybody can fiddle about with 'room correction' and obtain a ruler-flat response - or whatever target they arbitrarily decide on.Other producers have two thoughts at once. Doing one thing doesn’t rule out another. It depends on competence including resources.
To me, it seems like less resourceful producers use tactical arguments to favour their narrower position.
I thought Genelecs ‘active’ series were an advance ,that’s why I bought some , the 8Cs are a further advance and I dare say in the future innovative technology will produce an even better loudspeaker.
The ‘cardioid’ speakers here produce clearer more transparent sound quality than any other ‘traditional’ loudspeaker I have tried despite the addition of passive/active room correction EQ etc etc.
Not everyone can see that a room is a complete, consistent system where every wobble in frequency response is 'explained' by precisely complementary delays, resonances, absorption of different frequencies and so on. These remain precisely consistent in three dimensions as the listener moves their head. The room can never be 'wrong' so cannot be 'corrected' by changing the source - which just sounds like a weird source in the same room.
"Aha, but it's different for the bass" you may say, but even there, what you are hearing is precisely consistent with the room's effects on the other frequencies. If you fiddle with the bass on its own, it will sound inconsistent with everything else. You can't 'fix' a poor listening room by changing the source. Just get a bigger room or effectively create a new one by moving stuff around; fitting a carpet; changing the speakers' height, etc. Most likely you are simply not in a music mood that day. After that you are probably craving a change of room rather than suffering from an 'incorrect' one.
Geithain’s cardioid response is bass only and their coaxial consists of placing a tweeter in front of the mid, they are also not full range until you get to the 901s so not really the same , but I am going to get some Geithains to compare.Geithain have produced cardioid speakers for ages. Plus, they are coaxial and truer single-point.
In other words; nothing new under the sun.
Having said that, I like the idea of both cardioid and single-point. What I don’t like is selling something as new when the concepts have been implemented and tested for a long time. I try and avoid being fooled by «same shit new wrapping».
Erm. I can only see one straw man there!Don’t create a straw man. Nobody claims the room is unimportant.
Just as randomly playing with a graphic equaliser does. You may even like the novelty as you switch it in and out, and gasp at the extra detail you can hear on the violins or whatever. But it won't last.DSP lets you listen to the room correction filter by button click so you can decide for yourself if it meets one’s preferences.
I have compared (K3 vs 8351 in room). No big deal. Both are great. The 8351 sounds bigger and has better bass.Geithain’s cardioid response is bass only and their coaxial consists of placing a tweeter in front of the mid, they are also not full range until you get to the 901s so not really the same , but I am going to get some Geithains to compare.
I don’t believe EQ is harmful, sometimes it is the only solution, but I believe it is better not to create the issues in the first instance.
The benefits are completely obvious when you compare in your own room.
If the room was unimportant then we would listen in anechoic chambers - which would give the 'best' measurements. We choose not to do that because it sounds rubbish, and is an unpleasant environment.
Me too, I thought the Gens were good for close up a metre or so, but after that bass just became diffuse, the Kiis have a fairy narrow ‘band’ of soundstage, yesterday we compared the Kiis and 8Cs at a guys studio ( the chap posted his thoughts on the Gearslutz 8C thread) the 8Cs have a much larger in terms of depth and height soundstage.I have compared (K3 vs 8351 in room). No big deal. Both are great. The 8351 sounds bigger and has better bass.
The benefits don’t look very obvious from your own measurements. From your blog, your room has a gigantic mode at 40hz with the kiiaudio speakers. It also shows the mode with ATC speakers. In fact, it appears the 40hz mode is much worse with kiiaudio speakers.The benefits are completely obvious when you compare in your own room.
It's just by the power of thought experiment alone.I see your argument. But I can’t see your providing material support for your position that room correction is harmful in Hippocrates sense.
