- Thread Starter
- #81
Qes is a derive metric.Your own derivation actually confirms the point: beta is not an independent physical quantity.
It is algebraically derived from magnetic flux density B and from the geometry and material of the voice coil.
Those same quantities also define Bl.
The fact that beta can be obtained directly from FEM does not make Bl misleading or obsolet, it simply means that both parameters originate from the same underlying motor physics.
FEM can just as well be used to compute Bl from the same field solution.
Physically, the dominant term in both expressions remains B, the flux density in the gap.
Beta is therefore not a new degree of freedom, but a different representation of the same motor properties, with resistance and conductor volume folded in.
Sensitivity (SPL/1 W) is not determined by beta alone, but by the full set of parameters (Bl, Mms, Re, Sd, etc.).
Beta = convenient composite metric.
Bl = fundamental motor constant.
One does not invalidate the other.
So the issue is not scientific correctness, but interpretation and emphasis:
Bl is necessary but not sufficient.
Beta is a derived metric.
The disagreement is about representation, not physics.
Finally, repeatedly framing this as “heresy” is inappropriate in a scientific and engineering forum.
“Heresy” is a religious term, historically used by inquisitors to condemn dissent, not to resolve technical questions.
In science, disagreements are not settled by theological rhetoric.
SPL is a derived metric.
Only B is a fundamental quantity.
Both Bl and Beta are derived from B.
Heresy is used in this discussion as a metaphor to indicate false teachings in hopes of drawing attention to an important matter. This is a common technique for authors. It is not used as a proof of anything. All claims are quantified and no claim is proven by metaphor.
Why is Beta ignored in Date Sheets by all transducer manufacturers except Peerless?
