I understand that Harman target for speakers is anechoically flat. The reason I brought up the image you replied to earlier was because the Harman headphone target is basically the "subjectively-preferred steady state room curve target" for speakers.
@pozz said people want neutral speakers, and therefore, want neutral headphones. If neutral is anechoically flat placed in a well-treated room, that is not the preferred response in either speakers or headphones based on that image.
It's important to differentiate between measured response and perceived response. The graph posted in your video is a response measured by a microphone. That response includes the bass/mid waves reflecting off the back walls and front walls and then hitting the microphone. This is not the way our brain hears and determines what sounds "neutral". Our brain "hears through the room" and uses the anechoic direct on axis sound to determine whether or not the sound is neutral. The microphone measures a tilted response, but only because it's dumb; our brain hears a flat line, because it (correctly) identifies that the direct sound is flat outside of the room's influence("hearing through the room").
This applies to headphones because Harman started their headphone curve by targeting the perceived response, not the measured response. In other words, they didn't start by targeting the sound of a downward sloping line, they started by targeting the sound of a flat line, which just so happens to look slanted when you try to measure it outside of an anechoic chamber. Bass level does seem to be a matter of taste that sometimes deviates from ultimate neutrality, but it's important to recognize that the Harman loudspeaker target itself does not actually call for elevated bass.
I really do think Amir should do a video on this, as it's a very common misunderstanding, and I can understand why.
That said, it's also my understanding that Harman only started with the curve that best approximated the sound of a speaker that measures flat(anechoically), but have since deviated from that by adding extra bass. I think we kinda agree there.
Also important to reemphasize that curves y'all posted are not true "targets", as they only exactly apply for that particular room, at that particular listening distance, with those particular speakers. Because all rooms are different, there can be no in room target. The only true "Harman target" is a flat line, measured anechoically.
