I don’t know if it has been addressed but stereo is plant if used right
listen to some good "binaural dummy head recordings"
just search for "ASMR" on YouTube
(just kidding don't do it)
But this only works properly if the dummy head’s transfer function is close to your head transfer function.
and if you don’t move your head. (and listen with headphones)
Visual equivalent is this:
if you want to be able to rotate your had and all the sounds your recording are in the "far field" an ambisonic recording is sufficient
It is not relay "3D" but you can move your head.
the illusion brakes if things get to closes to the camera.
If you want to be Abel to move your head also laterally and have real 3d depth you need head tracking and a Wavefield recording or light field.
here it gets kind of complicated:
For the 360° you need a spherical sensor array the size of the area of you want to move in.
or if your a ok with having a small FOV you can have a planar sensor array
Your microphone then looks like this
But in the end after a lot of processing the delivery format for audio as well as Video is plain old "stereo"
Google created this rotating 16-GoPro arc to capture light field data for VR
Google has built a fascinating rotating light field VR camera rig using 16 GoPros mounted in an arc. The rig is meant to give viewers "a more realistic sense of presence” within a VR world.
www.dpreview.com
Google's 46-camera 'light field videos' let you change perspective and peek around corners | TechCrunch
Google is showing off one of the most impressive efforts yet turning traditional photography and video into something more immersive: 3D video that lets
techcrunch.com
