I guess you ruled out the Hasselblad due to the costs rel. to the Pentax 645Z?
How do you like the way the focus falls off with distance in med. format compared to FF or smaller sensors?
The Hasselblad that used the 50mp Sony sensor (like the 645z) wasn't available when I bought the Pentax, and the Hasselblad SLRs were just vastly too expensive. But I was already in the Pentax universe, with a decent 67 kit and also a couple of 645NII film cameras that I used for occasional side gigs. So I already had a body of lenses I could put on a 645z from day one.
Format is a continuum for me. Depth of field is related to focal length, and focal length is related to format. The bigger the format, the longer the lenses, and the less the depth of field at a given aperture. (I am not saying that 165mm on a 4x5 camera is any different than on a 35mm camera--it isn't, except that the small-format lens lacks sufficient field of view to light up the larger film area). The Sonnar 180 opens to f/2.8, whereas my fastest large-format lens is f/4.5 (for a 215mm Ilex Paragon). To get the same field of view as the Sonnar on the Pentax, I need a 135mm f/2 lens on 24x36, but I don't have one that is that fast. I do have a fast 85--f/1.8--and the Pentax 6x7 105mm, f/2.4 Takumar comes close to the same magnification and depth of field on the 645z. I can make any format do what I want if there is a fast enough lens, but I don't always have the fast enough lens. Of course, print size has to be constrained by what the sensor will support, but that's sort-of like comparing a big amp to a little amp and constraining the former to keep both in their linear range.
The Sonnar has a special look, though--perhaps a byproduct of its spherical aberration that is not fully resolved.
My "full-frame" camera is a Canon 5D Mk. II (I also have a Mk. I), now a dozen years old and recently back from Canon having received a complete overhaul. My wife uses a Nikon D500. Our family is therefore peaceful--neither borrows the other's lenses. But we are also poor as a result of buying crap in parallel.
Rick "who uses the format that is most convenient and fulfills the requirements" Denney
