The "DAC-as-Preamp" Trap: Why DAC Buffers Bottleneck High-End Amplifiers
Status
Not open for further replies.
SanojS
Hi everyone,
(And before you say anything, English isn't my 1st language and I've used AI to help me format and preread this text..., which is why you can see it looks like it is AI generated...)
I’ve been reading a lot of legacy audio reviews lately where reviewers enthusiastically claim you can "sell your preamplifier" because a new DAC has a digital volume control and variable outputs. A recent example that triggered this thought was a review of the older Bel Canto e.One DAC 2.5, where the author praised running it directly into a power amp, claiming it simplifies the signal path.
From an engineering perspective, this feels like an oversimplification that ignores basic electrical symbiosis. Calling these devices "DAC Controllers" or "Preamps" is marketing; physically, they are just DAC buffers with a simple dual op-amp analog output stage.
I've also seen multiple occasion here on ASR where people praise these "do-it-all" boxes as the core of good systems, saying preamps are a thing of the past. And yes, those type systems exists where you have a streamer, a DAC and a really excellent analog volume and preamp stage like for example Eversolo DMP-A8. But they HAVE to include a proper preamp section. Most don't and if they do, the price will reflect it.
I wanted to lay out the math on why running a DAC buffer directly into a power amp is often a major system bottleneck, and how the downstream load completely dictates whether this approach succeeds or fails.
I REALLY look forward to a discussion about the physics of these components, why some people ignore it, and why they shouldn't: or - if you think I am completely bonkers or wrong. All comments are appreciated! I am still learning about audio and I love it! I am an engineer (not in the audio or physics areas) and I am passionate about technology. If I'm wrong or made wrong conclusions, please help me to learn! I am in the study phase of learning how to optimize my new system and have spent 1,5 years reading and learning. Next year, I will start to build my "ultimate system" based on these principles like impedance and gain matching, phase shifting, current deliveries, sensitivity, etc...
The Technical Reality of the DAC Buffer
Most standard premium DAC chips feed an active I/V converter and a basic dual-op-amp line-driver stage. Many DAC makers point out high voltage delivery from their products (e.g., "4Vrms Balanced Output!") as a "proof" that it can seamlessly drive any power amp. But this is actually a trap. Voltage is just one of several parameters that determine if a product has the physical capability to match and drive downstream components.
If we look past the surface-level voltage numbers and look closely at the actual topology, the metrics look "fine" on paper as a source, but poor as a preamplifier:
  • Output Impedance: Typically sits around 100 Ω (RCA) to 200 Ω (XLR).
  • Current Delivery: Usually limited by the IC op-amp's internal short-circuit or linear drive limits, sitting around 20 mA to 45 mA max.
  • Slew Rate: Often ranges from 20 V/µs to 30 V/µs.
Compare this to a "proper," over-engineered analog preamplifier (discrete transistor or high-voltage rails). A dedicated preamp comfortably delivers 200 mA to 500 mA of current, boasts an output impedance of 10 Ω to 40 Ω, and pushes a slew rate well over 100+ V/µs.
Scenario A: Where the DAC Buffer Works (The Low-Demand System)
If you are running a budget-friendly or ultra-efficient near-field setup, running direct is perfectly acceptable.
  • The Chain: A variable DAC output to an affordable Class D amp (like a Fosi Audio ZD3 or ZA3) to a pair of high-sensitivity horn or monitor speakers (98+ dB @ 8 Ω).
  • Why it works: High-efficiency speakers require very little voltage swing from the amplifier to reach loud listening levels. The amplifier's input stage draws minimal current. In this scenario, the DAC buffer can comfortably live within its 30 mA envelope.
  • The Trade-off: You do sacrifice some digital bit-depth (dynamic range) due to digital attenuation at low volumes, but given the massive sensitivity of the speakers, the system remains highly functional and acceptable.
Scenario B: Where the DAC Buffer Chokes (The True High-End System)
When you move into demanding, low-efficiency hi-fi territory, the DAC-direct approach falls off a cliff, causing the system to sound flat and dynamically compressed.
  • The Chain: A variable DAC output to a current-hungry Class A/AB or high-power Class D power amplifier to a low-efficiency, complex-load speakers (below 93 dB, dropping down to a 2–6 Ω stable load).
  • The Bottleneck: Heavy, low-efficiency woofers and complex crossovers demand massive, rapid current delivery from the power amplifier. To modulate that power cleanly without phase shift or micro-sagging, the power amplifier's input stage demands an effortless, rock-solid voltage source.
  • The Physics: A 200 Ω source impedance from the DAC buffer interacting with cable capacitance creates an immediate high-frequency filter. Furthermore, when the power amp demands rapid voltage swings under heavy load, the DAC's small dual-op-amp stage strains to deliver the current required. The op-amps operate under high stress, leading to a noticeable drop in macro-dynamic "slam" and low-end authority.
Conclusion
A true analog preamplifier doesn't just change the volume; it acts as an impenetrable impedance barrier and a massive current reservoir between your digital source and your power amplifier.
Pretending a DAC buffer is a preamp just because it has a volume slider is like saying a fuel pump is an entire fuel system. It ignores the lines, injectors, and regulators working in symbiosis.
I’d love to hear the community's thoughts, bench-test experiences, or measurements regarding the measurable degradation of micro-dynamics and input-stage distortion when driving demanding power amps without an active analog linestage.
Source?
Sorry for being blunt but this is nonsense. There is no link between the power amp current delivery and the upstream component current delivery.
There is a link between power amp input impedance and the upstream component current delivery. A power amp with low input impedance will require more current. But even there, any serious opamp will do the job, unless the power amp input impedance is ridiculously low (below 600 Ohm).
I am a proponent of inserting an analog preamp between the DAC and the power amp but for a completely different reason: SNR at "normal" listening volume (between -30 and -10 dB) improves considerably with an high performance analog preamp.
I think of you want to discuss the science, you should also deliver complete numerical examples of where the problem you think exists is actually shown. Because right now, the input impedance of the amplifier - which would be critical for these examples - is fully missing and I do not see how your explanation shows any actual problem. I also don't see how the characteristics you do list would be critical for the setup you envision.
I would also appreciate if you could instruct the LLM to keep the answer concise, because it is quite tedious to read long texts with many fill words and very little actual info in them.
That seems ridiculously over-engineered. The low output impedance is nice, so you minimize the effect of cable capacitance, but the huge currents and slew rate are snake oil, I'm afraid. No real power amp needs that kind of drive current, and that slew rate is well beyond what audio requires.
Are there power amps with 8 ohm input or something?
I'm smelling a pre-advert for potential product placement, or a solution looking for problem to solve, or just a bid for a bit of fun-contentiousness. It would save time and effort to pick one, say such, and run with it.
I have a humble Topping DX1. The RCA's on the the back are not controlled by the volume pot on the front, so you have to be careful plugging into a power amp, for obvious reasons, but it drives one perfectly - it has plenty of voltage for most power amps with "standard" line-level input sensitivity. I see no quality issue. Power amp gain is fixed, and the output is dependent on the voltage at the input, and input impedance is always very large (so think what that means). Some DACs do have control over line-level output voltage that is not just dependent on bit-fiddling. Not sure which ones, but it's beside the point.
You know there are not, not even valve ones ! :)
Good valve ones had pretty high input impedance, since if you were lucky the preamp had a cathode-follower. But who knows what some goofy snake-oil power amp has.
Many DACs do of course have a post DAC R2R type digitally switched volume control. If well implemented it works well. But elaborate. The solution used by RME is simpler and in all practical cases matches or exceeds the performance of the very best preamps at a small fraction of the cost. I say exceed because RME do impeccable analog engineering which few companies match.
Sorry, but I believe the era of the standalone analog preamp is probably gone.
It's certainly on its way. But I know people that want tone controls, for example.
Reactions: EdW
Source?
Don't claim it is nonsense without facts, my friend. Let's look at some examples!
Here's Audiolab 8000Q (one preamp I am considering as good):
- Maximum Output: greater than 7.7 V rms (20 dBm)
- Output Impedance: 100 W nominal
That gives us a continuous RMS current capacity of 77 mA! Audio signals are dynamic, not continuous sine waves. To understand the headroom available for sharp transients (like a sudden bass hit), we convert the RMS voltage to its absolute peak voltage.
Vpeak=Vrms/square root of 2 -> 109 mA.
Another preamp I really like (since I have seen it for sale in my country): T+A P1000.
Vmax=9.5V
Output impedance=20Ohm
At maximum output, the P1000's line-stage can push an astonishing 475 mA of continuous current across its own output resistor network.
There you go, that's my source. Now please challenge me :-)
You are 100% correct that a standard power amp input (10k to 50k Ω) only draws a fraction of a milliamp and that theoretically the 200 Ohm/20mA is within usable range. In a mathematical vacuum, you don't need that kind of muscle I am talking about.
But it’s not about what the power amp demands; it’s about keeping the preamplifier's output stage completely unstressed and distortion free and maximizing performance:
Transistor Linearity is important. Small op-amps operating close to their thermal or current limits show rising distortion long before they clip. A discrete stage built for 200+ mA idles in its absolute most linear, distortion-free "sweet spot" under normal use.
Eliminating TIM Distortion: Yes, you only need a low slew rate to pass a 20 kHz sine wave. However, a high slew rate (100+ V/µs) ensures the negative feedback loop catches complex musical transients instantly (like going from a soft high note to a heavy bass note). If the loop lags even for a microsecond, it creates Transient Intermodulation Distortion (TIM). You want the system to be able to handle swings in amplitude and frequency effortlessly in engineering language.
Reactive Cable Loads: Interconnect cables have capacitance. High current capability allows the stage to charge and discharge that capacitance instantly, preventing phase shifts or high-frequency roll-off over long runs. This isn't snake oil and is a basic engineering concept well known in electrical engineering.
It is just classic engineering overhead to ensure the circuit behaves perfectly under real-world, reactive loads and leave headroom for peaks. Yes, you can run DAC directly with 200 Ohm and 20-40 mA. But you have no margin. And there are actually systems where this is not enough!
The golden rule of audio voltage transfer is the 1:100 ratio (the load impedance should be at least 100 times higher than the source impedance). A 200 Ohm source into a 20 kOhm amp sits exactly at a 1:100 ratio. It is functional, but it leaves zero margin. A true preamp dropping output impedance to 20 Ohm creates a 1:1000 ratio, creating an incredibly robust connection that makes the system completely immune to long cables, poor shielding, or high-capacitance audiophile cables.
I put disclaimer in text:
Engineering is mine, AI is my language help. I use Google AI to help with language.
I didn't write that it needed to be a separate component. The relay attenuator (not R2R please :) ) from some DAC is an analog preamp. Solution from RME is indeed very elegant. But it is still has an analog part to lower the noise.
As a north east of France native, I need some time to make friends with somebody. Maybe it will come one day but we are not yet there. Fact is that the current needed to drive a power amp is not related to the output current from said power amp but to it's input impedance. Pretending otherwise is nonsense.
Vmax=9.5V
You are calculating the short circuit current. A preamp output is presented the input impedance from the power amp, not a short circuit. The output current is V_out / (Z_out_preamp + Z_in_poweramp). For a 94k input impedance, the max output current from the Audiolab is 0.14 mA.
Maximum output current is related to the capability of the output stage and is usually not published neither measured by reviewers. To stay in the opamp world, some are limited to 20 mA while others can output 200 mA.
I want to thank everyone for these great questions and challenges!
Again I turn to a real life scenario.
One of my best friends has B&W 803D and he decided to go to 750W Purifi Class D amp since it is a very power hungry and low sensitivity speaker...
Minimum Impedance: 3 Ohm (drops down heavily in the upper-bass region, around 110 Hz–120 Hz)
Sensitivity: 90 dB meaning at 3 Ohm it requires some juice.
His 750W Purifi Class D module to get it to output that full power, the amplifier needs a preamp that can handle the input voltage swing (often requiring around 2.5V going up to 9V RMS in certain scenarios).
We have had a lot of discussions and questions about preamps and such for this system and he has tested 3 different versions. This is where I started to research... and hence my question I posted here. He has seen a huge difference in SQ impact. If preamp isn't able to drive enough juice, sound becomes flat and dull...
I have since looked at characteristics, what are the parameters that would impact such behavior because I have been in the modern variable DAC is enough for most camp. I have since started to swing to the other side, whereby I see a clear benefit electronically and physically on preamps - it is not only about volume control -> it is about gain matching, it is about current drive in demanding systems and it is about slew rate.
And if you check my original comment, you see I said there are cases where such a component is indeed very capable and enough to drive such a system. But I am looking at a different level of system where preamps are a must.
I like your replies MY FRIEND :-D
You are absolutely right that Vout / (Zout_preamp + Zin_poweramp) is the formula for a purely resistive load, and I agree with steady-state conditions, the current draw is small.
However, there is a minor error in your calculation: 7.7V / (100 Ohm + 94,000 Ohm) is 0.081 mA not 0.14 mA, but that is just a side note. More important, the formula applies to a purely resistive, static system. In the real world, we have to look at the physics of a dynamic, reactive loads. The Charging Current (I = C * dV/dt).
The amp input and cables are not just resistors, they have capacitance. During fast transients, source stage must push enough instantaneous current through the combined capacitance to charge it. If a sharp (fast) transient requires fast voltage swing (change of amplitude and volume dV/dt) the instant current will definitely spike, and whether it surpasses the 20mA limit depends on the exact speed of the musical transient (like 20mA in my example which is as far as I know a common rating on opamps used in DACs, correct me if I'm wrong...). If it hits the ceiling during the spike, the waveform might deform or compress - you don't get voltage clipping, you get slew rate limitation and transient compression. At least that's my understanding...
Over to you FRIEND :-D
Well, there is nothing preventing you from asking! I have answered two messages above with some real world examples, please let me know what you think about them.
I don't appreciate your snarky LLM answers. As I have said, I have studied this subject for 1,5 years and I have an electrical engineer degree and have worked in IT for 32 years... so I have a very good foundation for understanding the physics!
And hey - welcome to 2026! We can now have discussions across language barriers with the help of AI (also, I work with large language models and multi-Agent AI systems so I know a bit about that too, as well as the limitations of such systems - you have to know the subject when you use AI).
I didn't expect ASR has such people eager to jump to conclusions about me, my intentions and my background - you sound like you have anti-science bias and hate for AI/LLM!
AI/LLM is GREAT if you know how to use it! And absolutely a mine-field if you don't...
You still have to deeply know your subject when you use AI to ensure the core engineering principles are accurate.
Status
